Old 5th August 2014, 08:00 AM
Lyons Lyons is offline
Default Footrest/Dead Pedal
Has anyone ever changed the dead pedal for something a bit more sporty/grippy?
The chrome and rubber combo of the standard one in my Mk2 TT offered far more grip then the one in the A8 which is pretty much smooth.
I'm not really bothered about aesthetics of it or the pedals (thought the TT ones did look well), but I would prefer getting something with more grip.
Old 5th August 2014, 08:08 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Spray some of this on it?
http://www.plastidip.co.uk/eStore/in...r_Grip&stage=1
Does the peddle covers from a RS6 fit the 8?
They got chrome and rubber rest, brake and throttle I think.
[center]
06 3.0TDI Quattro:
Options:
Old 7th August 2014, 07:43 AM
I had a quick look on ebay yesterday to see if any were of a similar shape, but got nowhere.
I'll have a look at an RS6 one and compare to mine.
Old 7th August 2014, 09:23 AM
I thought the plastic footrest looked a bit cr@p and got a local engineering firm to manufacture one in aluminium treadplate using a spare rest as a template. Unfortunately they only had standard aluminium checkerplate /treadplate which has approx 25mm "square" 5 bar checkers which is a bit industrial. Its ok but not really right. They had satin finish smooth plate but that would scratch badly after a while. Still looking for something whcih would match TT type pedal (which I haventgot yet either!)
Old 7th August 2014, 09:32 AM
ScottD3's Avatar
Just need a sheet of steel/ally, cut some slots out of it and put rubber bits in them. Like all the others.
I had a mate who was going to make me one cause he makes them for the S3s but sadly he passed away so that's not going to happen any more.
[center]
06 3.0TDI Quattro:
Options:
Old 7th August 2014, 09:36 AM
Just need a sheet of steel/ally, cut some slots out of it and put rubber bits in them. .
Exactly. but its getting the right material cut and shaped and then getting the right rubber strips attached so that it looks good.
However, there is a possible solution in the offing......
Old 7th August 2014, 09:37 AM
Yeh, finding the rubber bits would be the problem!
Old 7th August 2014, 09:41 AM
What about a VW Phaeton one "modified"? http://www.ebay.com/itm/2004-2006-Vo...-/161120189434
Old 7th August 2014, 09:44 AM
ScottD3's Avatar
Something like this?
http://www.ebay.co.uk/itm/380952409930
[center]
06 3.0TDI Quattro:
Options:
Old 7th August 2014, 09:50 AM
Seen all those but I wanted something that replaced the entire plastic piece. I removed the plastic bit which wraps around the carpeted piece and got the fabicators to produce that entire footrest which I then, having removed the plastic one completely, glued on instead. Fixing a ally plate to the existing footrest is not what I want.
