Old 15th August 2014, 07:12 PM
All ok on vag com ... no fault codes and can see them on the optical bus ... no idea what it is .. its strange they just vanished ?
Old 15th August 2014, 07:50 PM
mannyo mannyo is offline
You could try the age old turn it off and on again. Last time I had a problem with the MMI, I disconnected the battery for 5 mins and it was fine again straight after reconnecting. Turning off the ignition may not be enough as the MMI might not be going to full power off.
Manny
Past
Old 15th August 2014, 08:07 PM
I will try that ... maybe it will re calibrate itself I guess .. all of this is since the tv module was changed to the didgi box dvb t
Old 15th August 2014, 08:12 PM
jza8's Avatar
jza8 jza8 is offline
I think it only shows CD - TV - AMI - AUX - AUX2 on there. DAB is with radio.
Since you replaced the tv module TV - AUX - AUX2 has gone which seems logical. The only question is should Digi Box show up there?
2010 Audi A8 4.2 TDI
Old 15th August 2014, 08:37 PM
Yes because on the W12 with dvbt works perfect ?
Old 17th August 2014, 06:56 AM
m going to update the mmi software and hopefully that will sort it out I changed the mmi brain and it had TV options ect but the soft ware is out of date and dose run a tad slow so il update and see if it cures it ...
Old 18th August 2014, 08:08 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
The option to change what sources you got was in the hidden menu I think.
I swear I seen it in there.
Go in and have a look under the tuner menu.
[center]
06 3.0TDI Quattro:
Options:
