Old 26th August 2014, 06:51 PM
Mr_V Mr_V is offline
Default Ski Bag??
I gave my interior a thorough going over and discovered a long 'bag' tucked away behind the rear armrest. I'm assuming it would be for skis.
The problem is, it won't fit back in, and I can't close the hatch. Is there a easy solution for this?
Old 26th August 2014, 07:27 PM
If you have the ski bag, you'll also have the hatch in the boot, you could open that to give you some space to try and tidy it up for folding back in.
Old 26th August 2014, 08:24 PM
Professor Peach's Avatar
I would have this problem in my B5 every time any one got in the back seat and said 'what's this for'. No quick solution really, just fold neat and tight. Handy for collecting timber from B&Q though.
Old 26th August 2014, 09:12 PM
Some many times I was crying because of not being able to just go and pick some timber up from B&Q, I always have to ask someone
And that sometimes postpones so many DIY projects which I can't be bother to do later if I can't do it right now
Old 26th August 2014, 09:54 PM
I'm not sure how the D3 ski hatch is constructed, but I retrofitted it into my (FL) D2 and decided to leave the bag (elephant condom!) itself off - it's stored under the boot floor next to the spare wheel.
If it's similar (might be identical) it just clips back into place with plastic lugs around the rim. Very easy to fit and remove, takes seconds.
To do this open the cover in the boot and just push the frame into the channel around the hatch and the clips engage.
Obviously this involves reaching deep into the boot and getting some decent light source so you can verify you have it all the right way round and right way up.
Old 27th August 2014, 05:13 PM
texas2201 texas2201 is offline
I have the ski bag and surround off my scrapped D2 if anyone is interested - currently on ebay
http://www.ebay.co.uk/itm/3012895328...84.m1555.l2649
Old 27th August 2014, 07:08 PM
Thanks for that. I will do it when I get my wheels back. I'd rather not be clambering about in the boot when it's on four stands.
Old 27th August 2014, 07:19 PM
Originally Posted by Mr_V View Post
Thanks for that.
I don't "know" it's the same, but it seems likely to be, or very similar. The D2 Elephant Condom definitely is fitted/removed from the boot side.
If you look carefully at the frame on the tube and where it fits onto the method and orientation should be obvious.
Old 27th August 2014, 10:53 PM
iirc the whole D3 hatch mechanism removes quite easily, much easier than the D2 that requires the back seats out.... I discovered this when transferring the fridge from my 4.2 Tdi to my S8 (which Oli promptly negotiated back!) as it was a very easy clip in / clip out....
Old 28th August 2014, 07:55 AM
Only PF as some fixing bolts are hidden behind the rear backrest, FL is pretty simple as they are directly accessible.
If it's that easy on a D3 it might be easier to remove it all to refit/reorganise the actual bag. (On D2 I found it easier to fit the frame without the bag there)
