Old 26th August 2014, 05:55 PM
nigelw1982 nigelw1982 is offline
Default any help be appreciated
my friend got a S8 4.2 V8 on full throttle it back fires and the fault logged is throttle position sensor on looking on elsawin its a cable fly by wire setup with a potentiometer i wonder of theres any audi nuts on here that can help solve this conundrum
Old 28th August 2014, 10:14 PM
roboblob roboblob is offline
what year is the car ?
Old 28th August 2014, 10:23 PM
I don't see any connection there.
What EXACTLY is the fault - full details & text please?
Clear the fault and see if it returns IMMEDIATELY after a misfire event.
And, as requested above, what engine exactly is it and what model year?
Old 31st August 2014, 12:06 PM
its a 1998 4.2 V8 S8 did the fault code reading cleared the codes changed the throttle position sensor the only fault that seems to be returning is this one
17968 - Maximum Engine Speed: Engine Warranty VOID!
P1560 - 35-10 --) - Intermittent
does anyone have any way of knowing exactally what this means there is still a misfire on full load under kick down but the sensor is working fine
Old 31st August 2014, 12:34 PM
Check the measuring blocks for misfire, I think it's around 17-19 to see if misfires affect all cylinders equally or some cylinders or one bank more than others to determine if it's general problem or only for some of cylinders.
It is possible that engine have experienced mechanical damage due to over-revving going by error code and that this damage causes misfires.
Old 6th September 2014, 07:17 PM
i have the s8 with me now i will be checking the blocks from 17-20 just checked all the wiring on the oil packs and they all seem to be ok from pin 4a with good continuity to engine earth, checked all the resistances on the coils outer 2 terminals and getting a range from 3.0 ohms to 3.9 ohms will post the actual results along with full compression test info soon
Old 9th September 2014, 06:35 AM
Bandycoot Bandycoot is offline
I've just checked the fault code in the Ross-Tech wiki. This is what it cme up with.
17968/P1560/005472 - 17968 - Maximum Engine Speed Exceeded
17968/P1560/005472 - 17968 - Maximum Engine Speed Exceeded (Engine Warranty VOID! ☺ )
Possible Symptoms
## Abnormal Engine Noises
Possible Causes
## Rev Limiter Removed, check to see if ECM has been 'Tuned'.
## Engine Speed too fast due to a mis-shift or the "Money-Shift".
## Stuck throttle.
Possible Solutions
## Clear Fault Codes
## Remove Lead from Foot
Special Notes
## This DTC indicates that the Engine Speed has passed the recommended safe RPM limit, which may potentially cause severe engine damage.
I don't know if this will help.
2001 D2 S8. Volcano black. KW Variant 1 coilovers. EBC Turbo grooved discs with Yellow Stuff pads. 19 inch R8 replica wheels with 255/35/19 Michelin Super Sport. In the UK, 1990 Audi 90 2.3 20v Quattro with just 65,000 on the clock and in mint condition.
Old 9th September 2014, 10:23 PM
have cleared the fault codes and it returns even after a gentle responsible drive looking in elsawin it just says over revving and doesn't give any indication to weather it could be a crankshaft sensor or something similar. there is no abnormal engine noises sounds sweet as a nut gonna do a wet and dry compression test on the internals see is theres anything untoward going on but i don't think there will be bonn check all resistances injectors and crank and cam sensor connections try and rule out as much as i can change the fuel filter in case its being starved of fuel throttle body been stripped down cleaned and new gasket fitted and re coded to match i dont know weather its been remapped how would i check that and the will check the rev limiter after all internal test have been carried out
Old 10th September 2014, 06:38 PM
all injectors are around 18 ohms stone cold engine tested outside not at room temperature all spark plugs checked all bosch super4's and of good condition, checked the hall sender 4.5v on pin 1 good earth on pin 3 0v on pin 2 should get battery voltage on that but will know more when i run some more test with VCDS. good resistance on the air injection supply 31 ohms, checked coils good earth on 4a 3.0 ohms on each of the coil packs
compression pressures
1= 110 psi
2= 120psi
3= 110psi
4= 120psi
5= 105psi
6= 100psi
7= 100psi
8= 100psi
all these compressions were carried out on a stone cold engine not at min oil temperature of 30 degrees (what elsawin requires) or operating temperature dry of fuel as a problem with fuel line awaiting delivery of a new replacement.
Old 10th September 2014, 06:48 PM
Sounds like you have checked all the boxes as it were, one question though. You say pin one has 4.5v and pin has nothing.
I haven't read elsa win but is that correct. I would have thought there would be ov, supply and feedback that ideally you would need to check with an oscilloscope?
