Old 31st August 2014, 06:39 AM
Default Couple of bits for sale D3
TV tuner standard £60 posted
DAB radio module £80
ABS module £60
W12 starter motor £100
MMI Brain £300
4.2 front brakes pair with discs £120 360mm
PF lower grill £40
Wide dis clocks £120
Rear Quad zone pannel £ 40
Will upload pictures soon
Old 31st August 2014, 07:45 AM
Guy, how involved is fitting the DAB module if you only have the standard tuner. Does it require CP removal.
Old 31st August 2014, 08:45 AM
You have to upgrade you aerial amplifier to one with at least DAB connector (black) on the very end. If you have a TV then you need to upgrade to one with all 4 TV fakra connections and black for DAB.
than a aerial cable with fakra plugs on both ends, harness and you are done.
No CPC.
Amplifier 80quid (just DAB)
http://www.ebay.co.uk/itm/AUDI-A8-D3...item58b3edb1f0
Fakra cable
http://www.ebay.co.uk/itm/120994817615
Harness
http://www.ebay.co.uk/itm/121322463251
Full guide done by Tristan here
http://forum.a8parts.co.uk/showthread.php?t=8151
Old 31st August 2014, 11:36 AM
I suppose brakes would not be straight fit to PF D2 with steel hubs, would it?
Old 31st August 2014, 10:17 PM
Nope.. needs the newer ally hubs.
Old 2nd September 2014, 08:17 PM
Its not too bad you need to connect the black cable to the clips inside above the rear window where the aerial is located. As MA8 said
Old 2nd September 2014, 09:09 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
The wide dis clocks petrol or diesel?
Please say petrol!!
[center]
06 3.0TDI Quattro:
Options:
Old 6th September 2014, 08:47 AM
Petrol ones
Old 9th September 2014, 04:44 PM
ScottD3's Avatar
The wife and wallet is happy with that information.
[center]
06 3.0TDI Quattro:
Options:
Old 26th March 2015, 07:15 PM
Are the brakes still available?
