Old 11th September 2014, 07:24 PM
If it would happen with me I'd change whole engine.
From donor car or perhaps just buy new from Audi if they are still available.
But you have to love your car to do that.
If you don't love it -- get rid of it and simply buy what you love.
Old 11th September 2014, 07:35 PM
Phil303 Phil303 is offline
Can I have your RNS-E?
Old 11th September 2014, 07:38 PM
gninnam gninnam is offline
Looked at buying an engine but you don't know what you are buying - 40v start at around £1.5K, then fitting and who is to say that this isn't damaged internally????
To much of a risk and plus, the gearbox has never been touched so the decision is made
Do really like (love) the car but at the end of the day, money doesn't grow on trees......
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 11th September 2014, 08:03 PM
Hi Andy
I'm really sorry to heat that
I agree with Nollywood and I think you've made a very good decision base on your circumstances.
It's a great loss for your family, but its the most sensible decision.
So sad to see her go...
Old 12th September 2014, 06:43 AM
There are a few '8s on ebay for around £600!
Old 12th September 2014, 06:56 AM
Nollywood's Avatar
Indeed, there are, I was looking at a few last night.
The only issue is this - how much more reliable would any of these be, compared to Ginnam's broken A8? A £500 car could last for 10 years with just service / maintenance issues.
Or it could go bang a month later, then he'll be back to square 1. I believe older D2's are best for wrenchers, or those who may have friendly garages to cater for their needs.
For a non-techie, a newer car, or a late D2 with a solid warranty is the way to go.
Old 12th September 2014, 10:13 AM
Sad news Andy. I loved that car, it reminded me so much of my very first A8. 2K is however too much to chuck at a D2 these days I believe, unless everything else is 110%, so I think its a wise, but sad choice....
Old 12th September 2014, 10:34 AM
Cheers Ian.
Yes, she will be going (just waiting for the garage to put it back together so I can get it).
Rang A8 Parts and they have offered me some money (not a lot)
I might have someone else who is interested for a bit more so waiting on that.
If any one wants to make an offer then please do.
It is well specked and also has the RNS-E head unit!
Andy.
Current cars:
BMW i4 M-Sport
Old 12th September 2014, 10:45 AM
hmm how much for the RNS e andy
Old 12th September 2014, 10:51 AM
I have to agree that if the car is tatty and with gearbox being at high risk, it's probably not worth spending over £2k.
However it does not have to be 2k for blown gasket, you just did oil cooler pipe replacement yourself so clearly you can do the spannering yourself. I would at least get the head off and inspect the damage and possibly attempt budget repair if the head are OK and gasket looks to be the only issue.
You only have to do both sides if you are skimming a lot(over 0.1mm) off head due to damage or warped head as this would cause difference in compression ratio between banks. Normal skimming is only couple of thousands of mm and will not make much of a difference so you can do only one side or if the head is straight and without damage to the face you can get away without skimming at all. You can do basic checks for the head visually yourself and with the help of bit of chalk and kerosene or diesel check for cracks or leaking valves.
Gaskets does not have to be £200 per side if you shop around. Below is the screenshot of example after a quick search if doing one side only. EUR146 or EUR 106 if you reuse old bolts. Posssibly find them even cheaper with a bit more searching.
Cambelt, rollers and water pump - depending how old they are, I would be tempted to change just the belt if bearings in rollers and pump are OK and without play, possibly put a fresh grease in bearings. So it is possible to turn it around for couple hundred instead of couple thousand.
