Old 22nd September 2014, 08:19 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Suspension Arm Supplier
Had the A8 on the ramp several weeks ago and noticed a couple of the lower arms are almost on their way out.
I thought I would try to find a decent supplier of MyeleHD arms in preparation for when they need replacing.
Has anyone got found a good supplier for MyeleHD arms?
I'm no longer in communication with the company that sorted me out last time.
[center]
06 3.0TDI Quattro:
Options:
Old 22nd September 2014, 09:18 AM
I used these guys when I bought my upper arms - delivery was a bit slow as stock came from Germany but they were the cheapest at the time (2012)
http://carpartscentreuk.co.uk/
These guys are generally quicker to ship but a bit pricier - helps to have the Audi part numbers to search for the correct Meyle HD numbers, and to check if any full kits they might do actually cover everything you need
http://www.allgermanparts.co.uk/
Old 22nd September 2014, 12:24 PM
Scott, have you considered Lemforder arms??
I was going for Meyle HD, but then after talking to few people in here and then with few people in the industry I went with Lemforder arms.
Lemforder is the OEM supplier and as expected my arms arrived with audi rings grind off for less £££
I got them from Mister Auto as recommended by Neil and I found this supplier to be very good
Old 22nd September 2014, 01:32 PM
ScottD3's Avatar
Lemforder is an idea.
But I've not dealt with Lemforder before, only ever used MeyleHD arms and been impressed.
They covered 50k miles in my A4 in 3 years without any issues or signs of wearing out.
I can't seem to find a Meyle kit for the A8 D3, found a D2 kit though.
M-A8, where did you get yours from?
Was it a complete kit of every arm, nut and bolt needed?
[center]
06 3.0TDI Quattro:
Options:
Old 22nd September 2014, 03:52 PM
I found it easiest to ring All German Parts to find out if there's a full kit - you will then need to check that the full kit actually includes all the bits you need, as some may be non-Sport spec etc.
Worth a visit to TPS as well to ask them to print you off the correct Audi part numbers for your exact vehicle VIN and use those to cross reference part numbers - takes the guesswork out of it
Old 22nd September 2014, 04:13 PM
From here Scott
http://www.mister-auto.co.uk/en/audi...and-suspension
I did not get the kit as I needed only all four front upper suspension arms.
Sort each category by Lemforder and see if they have all what you need
Marcin
Old 22nd September 2014, 04:43 PM
ScottD3's Avatar
Adrian, time is not an it's money really.
I got ETKA, so I'll have a look through and list all the bits.
Thank M-A8, I'll take a look.
[center]
06 3.0TDI Quattro:
Options:
Old 22nd September 2014, 04:51 PM
My suggestion to try TPS was purely to get a VIN specific print out for your car of the right Etka page to save you the time of looking through checking PR codes Just get them to print it off with the text page and scribble prices next to your part numbers - then you've got all the info you need for cross referencing the alternatives without a lot of guesswork
Old 22nd September 2014, 05:00 PM
ScottD3's Avatar
I understand that.
The TPS down here is a bit of pain.
They have never been very helpful to the public, you need to be trade or they turn you away.
I might try again lol
[center]
06 3.0TDI Quattro:
Options:
Old 22nd September 2014, 05:48 PM
ScottD3's Avatar
I got on ETKA and got my part numbers.
I will double check this but thought I'd paste it here a point of reference for me and anyone else who might find it useful.
RIGHT
Rear Lower
Audi: 4E0 407 694 N £185.35
Meyle: 116 050 0066/HD £89.95
Lemforder: 27147 01 £111.99
Rear upper
Audi: 4E0 407 510 E £117.82
Meyle: 116 050 0016/HD £69.95
Lemforder: 27030 01 £77.99
Front Upper
Audi: 4E0 407 506 E £117.82
Meyle: 116 050 0063/HD £69.95
Lemforder: 27028 01 £77.99
Wishbone Link
Audi: 4E0 407 151 L £217.50
Meyle: 116 050 0067/HD £104.96
Lemforder: 27145 01 £125.99
Drop Link Left/Right
Audi: 4E0 411 317 F £39.66
Meyle: 116 060 0028 £19.59
Lemforder: 30536 02 £19.80
Tie Rod End
Audi: 4E0 419 811 E £78.50
Meyle: 116 020 0020/HD £35.59
Lemforder: 25336 01 £51
LEFT
Rear Lower
Audi: 4E0 407 693 N £185.35
Meyle: 116 050 0065/HD £89.95
Lemforder: 27146 01 £111.99
Rear Upper
Audi: 4E0 407 509 E £117.82
Meyle: 116 050 0015/HD £69.95
Lemforder: 27029 01 £77.99
Front Upper
Audi: 4E0 407 505 E £117.82
Meyle: 116 050 0042/HD £69.95
Lemforder: 27027 01 £77.99
Wishbone Link
Tie Rod End
EDIT: I Might have got carried away.
EDIT 2: I added Lemforder.
EDIT 3: Added Audi Prices.
[center]
06 3.0TDI Quattro:
Options:
