OMG, be careful with those ramps!
I'd rather drive on left |
Coincidentally - my 'trade' discount is only a few quid more than Adrian's 10%
Iv not found another supplier as of yet - my company has an account with ZF but are only allowed to buy certain things. Im quite friendly with Mackies tho - if they can get the flange & seal im sure I could arrange a discount of sorts. |
Mate just rang me to confirm he'd compared new and old and could see no difference in the machined area - he was about to pop the old seal out to confirm that's got the extended lip on it. Bit galling as having ordered it from TPS I don't think they'll take it back, unless their ordered in parts policy is based on stuff coming from Germany rather than Milton Keynes. Guess I'll find out when I try later on!
Adrian, I'd suggest to replace both flange and seal anyway. Because old one is already removed it won't cost you any labour and will give you additional peace of mind there was no wear on old flange which may has leaked because of that...
Hi Sergey
It's been back together since before 12 today - the old part was inspected and the sealed surface is as new. My friend who works on the car said it basically looked no more worn than the new one. I have kept the new flange and will see if it has fixed the problem before I return in - on the basis that the labour to do the gearbox oil change and replace the seal was £80 if it means going in there again it's only going to cost me £40 or so in time ![]() I have my suspicions that these seals are actually quite old and been stored for years in less than ideal conditions - it would at least in part explain why some people seem to suffer issues much more quickly after a seal change. The seal that came out of the car was intact, but obviously destroyed in the removal process. Will put some miles on the car on Sunday driving to Slough to race toy cars so if the remaining surface oil has burnt off by then it should be possible to confirm whether the seal is now oil tight. Despite the smell of oil and the length of time it was leaking there was still plenty of oil in the centre diff, I'm told.
I've done around 150 miles since I changed my seal, today when the car was on the ramp I had a look at the seal again and it's completely bone dry. The seal I fitted was very pliable, definitely not old stock. If yours does spring a leak, there's another trick you can try, you can pop the spring out of the seal, unscrew the part where it's joined then snip a couple of mm off it. Screw it back together then reinstall the spring into the seal. This will marginally increase the force that the seal puts on the shaft and the chances are you will have a more reliable seal. I've used this method a million times and it always works.
Yes, can you let me have the part number please?
It's the same one I've got listed on the 1st page - if you're in no desperate rush to get the car back I'd allow the garage to remove it first and check the seal and flange design. It seems late cars may well have left the factory with this modified part fitted.
An extended lip to the seal will also confirm this, as well as the additional machining in the flange to give that lip somewhere to sit I plan to get mine up in the air next week to check the seal has done its job - if so I'll return the flange I bought to TPS - it'll cost me 15% surcharge, but that's less to lose than selling it on, I suspect
Sure. The part number is: 01V 409 809A
And photos can be seen here: http://forum.a8parts.co.uk/showthread.php?t=8844 |
#30
Thanks, I'm going to check this afternoon and get back to you.
UPDATE: Sorry to mess you about - Mackies told me it was on back order yesterday, but today they said they'd ordered one and it should be in tomorrow.
2002 Final Edition S8. Ebony black with Silver Grey leather and myrtle wood trim. Current mods: solar sun roof, 20mm rear spacers, 15 mm on front, red brembo callipers, 6k headlights, rear view camera, engine remap, alloy dash dial rings, alloy navi rings, tt/phaeton pedal upgrade, (and custom matching foot rest) dension ipod interface & parrot hands free kit (both fully hidden), av input, tv in motion switched thro' PF switch in blanking plug right of steering column, Audi 'quattro' sill covers, repositioned centre console switches, radio clock, .Planned mods: auto-dimming rear view mirror, dash cam (as steamship's), fit the ski hatch, refit philips drl's (or maybe not - nope, definitely not - horrible botch!). Last edited by The_Laird; 8th October 2014 at 02:04 PM. |
