#131
Enormously unlikely but since you have eliminated all the ignition/injection issues and you aren't getting fault codes and as it seems to occur on random corners/slopes have you considered the possibliity that there's a physical issue that's the cause? If some of the baffle stuffing or one of the catalysts are moving/loose it could act as a partial blockage cutting the power dramatically and as you turn/accelerate/release the throttle (or whatever restores the performance) it could then return to the correct position and it drives normally again. It isn't likely but not an impossibility and you might not have thought of it? Trying to think outside the box here
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound. ![]() Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting. Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids ![]() |
#132
Left field ideas welcome.
![]() One of the cats was rattling when I bought the car, probably still is. Passed 2 MOT's since though.
#133
Perhaps It could still function correctly (I.e. Pass the emissions test) when not in the shifted (and blocking the exhaust) position, as long as the gas can get through the catalyst to react it will convert the gases still? Not sure how you could check it but stranger things have happened
#134
I know it's only a few days, but the last time I experienced any oddness (low power, high revs at medium throttle) was about a week ago when I turned right at a T-junction on the A595 in Cumbria where it is joined by the A5093 at the coast near Silecroft.
After that I proceeded straight to the Hardknott pass which gave the gearbox a "good seeing to" on both 1 in 3 up and down slopes. During and since that journey it's felt fine. http://forum.a8parts.co.uk/showthread.php?t=8864 I wonder if there was some "redistribution" of fluid (or air bubbles or sludge?) as a result........ ![]()
#135
Just a quick observation, your power issue seem recently to be joined with sharp turns. Is there something amiss with your power steering pump? I remember when on full lock in my old D2 it used to cause the revs to dip slightly.
Also with regards to rattling cats, that was definitely a cause of power drops in my car, at times it felt like it I had thrown out the anchor, as the material in one cat used to move and block my exhaust flow. Last edited by Reffro; 8th October 2014 at 01:45 PM. |
#136
Could it be ESP sending torque reduction request to ECU as this seems to happen on hills and turns maybe roll, yaw or acceleration sensors inside ESP unit are not reading quite right always. poor connection, dry solder joint maybe.
#137
Yes, it's definitely associated with sharper turns, though not hard ones as it's usually at low speeds so minimal lateral forces.
I think the acceleration and yaw sensors are under the drivers seat so maybe I'll try to find and re-plug those. The yaw sensor sounds more relevant. But the condition 100% clears with a twitch of the throttle (lift off and reapply) so I'm dubious, unless that somehow makes the relevant ECU have a rethink? ![]() If it was readily reproducible I could try with ESP off and see if that changed things, but it's not predictable enough.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 8th October 2014 at 02:30 PM. |
#138
Maybe the steering angle sensor as well, giving incorrect readings, so causing the car to think that there's a slide on..
Do you get the ESP light flashing when it does it? That would maybe point it more to the cat/PS pump if not.
#139
Definitely NEVER seen any ESP light when this happens.
#140
