Here we will post links to Transmission related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
ZF Service Centers in the UK Online ZF Catalogue - Architex_Ma8tey (ensure you select English from language at bottom of page). Statement from ZF concerning Gearbox oil changes vs sealed for life - found by Completelylostagain TRANSMISSION Parts Catalogue - CtL Transmission Service in Germany- Ian@a8Parts via bimmerboard.com Strip down and repair of 1 to 4 clutchpack with lots of pictires - SyncroS8 5 Speed Transmission Service - Audipages F125 Transmission Switch Replacement- Audipages Transmission Removal and Replacement- Audipages Whinning Noise after filter change remedy - TozoM8 from Audiworld found by Jayzee D2 Gearbox Oil Change using TECH-TRONIX ATS355 Machine (suckypumpysquirtythingumajig) - notorius Gear leaver Stuck in Park - Simon Wallwork Throttle Position Sensor TPS modification for transmission hunt - Squeeto on Audiworld Recalibrate the Throttle - Paul W on TSN DIFFs AND FINAL DRIVE Transmission and Final Drives Fluid Level Checking and Filling- Audipages Replacing the Transmission Output Flange Seals-MikkyJane Replacing the Transmission Output Flange Seal- Audipages Replacing the Final Drive - Rear Output Flange Seals- Audipages Final Drive - Rear Input Seal Replacement- Audipages Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky. Last edited by Conan_the_Librarian; 22nd September 2017 at 08:46 PM. |
Sticky Updated
