Old 24th October 2014, 12:00 PM
ricky302 ricky302 is offline
Default Fuel distance till empty
Just filled my 1998 S8 fuel tank to the brim and the computer is saying 255 miles left till I run out, this can't be right surely?
90 litres = 255 miles = 13mpg!.
Is there a way to calibrate this or is something not right?
I own a 1998 Jaguar XJR and a 2001 M3 also and they're nowhere as bad as this.
Old 24th October 2014, 12:08 PM
Hi and welcome to the forum.
If it's like the D3 then you have to drive a bit so the computer can calculate the range based on your current consumption. If you're sat in city traffic then 13mpg sounds about correct.
Matt
Old 24th October 2014, 12:41 PM
The PF D2 was the same, it's based on the last little while of driving, so if you hit a nice long stretch of road, it'll start to climb up.
Old 24th October 2014, 12:44 PM
It calculates that figure depending on your recent driving history: so that suggests that you've just been either:
1 - doing a lot of urban stop/start driving and/or
2 - hoofing it a bit (only you know which…).
It should recalibrate if you then start to drive it on longer runs (e.g. motorways): my wife would typically find that she could drive it for more than a hundred miles before the "remaining range" figure started to fall….
Not the most sophisticated system, but ok once you get used to its logic.
Old 24th October 2014, 04:25 PM
Like said before it depends on recent driving. I have got it showing 150 when flooring it and 500 doing steady 50mph on speed limited motorway roadworks. Under normal circumstances it is showing 300-320 miles on full tank for me.
Old 24th October 2014, 06:19 PM
Cheers everyone, I have only had the car a week and in that time the airbag light came on and it's run out of fuel with a quarter of a tank showing.
Old 24th October 2014, 06:32 PM
sarg sarg is offline
It is 16 years old, any car of that age is gonna have teething problems
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 24th October 2014, 08:18 PM
Running out of fuel is common, how much fuel did you put in to fill up from there. i am guessing the problem is the usual issue with the fuel pump. Sometimes when its replaced, its not seated correctly as its a ballache to do and the result is that the lift pump cannot get fuel from the second half of the tank once the level drops.
Old 24th October 2014, 08:27 PM
I put in 75 litres to fill it up, I take it since it has a 90L tank 15L is sitting in one of the sides unused?
1990 Nissan GTI-R
1998 Audi S8
1998 Jaguar XJR
2001 BMW M3
Old 24th October 2014, 10:44 PM
I recognise that S8 - did it come from Swindon by any chance?
