Old 30th October 2014, 09:22 AM
Deek Deek is offline
Default I require Driver Side Adaptive Headlight
Hi All my car has a Driverside Headlight which must have been for left hand drive car, so it dipps to wrong side for UK, I can not see number on it, but the nearside headlight is 4E0941 BF I have searched to fin a replacement but none seam to have this number, any help would be appreciatyed, I als want to replace all bulbs in headlights and driving lights with a good brand that are brighter than existing ?
Cheers Deek
Old 30th October 2014, 10:13 AM
A8 headlights are universal as far as I remember. Some say there is a lever to switch the beam from Uk to EU, but this also is done by the VCDS, Tourist Mode is called or something like that.
How about adjusting the beam first manually? There are two white caps/alan key screws at the top, close to the wing.
One does the height, second one moves the lens from left to right.
Old 30th October 2014, 12:47 PM
the lever is on D2 headlights Marcin
Old 30th October 2014, 01:12 PM
Not even on all of them, only the early ones, I think with just dipped Xenons, not the dual ones.
Old 30th October 2014, 02:02 PM
Thanks for clarifying this guys, and yeah, I couldn't find one on mind so I thought they are only on earlier D3s.
So, I would try adjusting the beam first with two screws at the top
Old 30th October 2014, 11:00 PM
If they are xenon then you simply re code it for right hand drive UK in vcds and they will auto switch over.
When I drove to France I just plugged vag com in and changed it to left hand drive and it sets the beam for you.
They are universal lights 100% just re code them
Old 30th October 2014, 11:02 PM
P's if you don't have vag com depending on where your based you are welcome to drop by and I can do it for you
