Old 17th November 2014, 08:46 PM
Default Aux inputs on TV tuner
Hi Guys,
Tonight I tried to fit my iphone streaming gizmo only to find that the Aux in is not accepting a video signal.
The audio is ok so I need to investigate the problem, but for the life of me I can't find wiring diagrams for a aux input in elsawin or ebahn.
Am i being stupid?
If someone has the diagram and could post I would be very greatful
Wouldn't mind a link to people selling the harness either, cheers
Old 17th November 2014, 09:00 PM
Check them Del, they are absolutely top guys along the Kufatec, well known across the globe for their kits.
And in the mean time I will look for the diagrams and hopefully (but unfortunately by not finding it either) I will proof you are not stupid
http://vnsmedia.shoper.pl/
Change language to English on the right hand side
Old 17th November 2014, 09:16 PM
This could be silly but have you explored all the media player diagrams??
Old 17th November 2014, 09:25 PM
I think that relates to the AMI???
Old 17th November 2014, 09:27 PM
The harness I have fitted at the minute is into this unit (blue plug
Old 18th November 2014, 06:38 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
This any good?
http://www.audiworld.com/forums/a8-s.../#post24353718
Manual Video- In Adapter A6 4F, A8 4E, Q7 4L
Please disconnect the battery before starting installation.
The TV receiver has to be removed of the left hand side of the trunk (Q7 right hand side). Remove the 20-
pole red connector. Remove the red housing and put the single looms of the adapter into the black
connector as follows:
PIN-configuration:
[PIN 09 – Shield Audio left/right] [PIN 15 – Shield Audio left/right 2]
[PIN 10 – Audio signal white, left] [PIN 16 – Audio signal white, left 2]
[PIN 11 – Audio signal red, right] [PIN 17 – Audio signal red, right 2]
[PIN 12 – Video signal gelb] [PIN 18 – Video signal 2]
[PIN 13 - Video/ Shield ] [PIN 19 – Video/ Shield]
Video output (only for Hybrid-Tuner):
PIN 4 – Video Shield
PIN 5 – Video signal
PIN 6 – Audio Shield
PIN 7 – Audio left
PIN 8 – Audio right
[center]
06 3.0TDI Quattro:
Options:
Old 18th November 2014, 07:28 AM
That's what I used and they work.
The video is just one pin and the audio already works, check the pin from the blue connector to the prong in the middle of the RCA video connector for continuity with a multimeter.
If that works try a different video source. eg many digital cameras come with a cable to show photos on a TV.
Do you have any picture? such as a black and white rolling one?
There is a PAL/NTSC setting in MMI if I remember correctly.
Old 18th November 2014, 09:04 AM
snap nearly has it, turn on the ipod and set it going, then go to the mmi and change the video settings, ussually changing them from pal to ntsc save it and then change it back will get it working.
dont know why it happens but it does
Old 18th November 2014, 10:13 AM
Cheers guys, I will have a look today at some point.
I'm hoping it's the pal/Ntsc thing as I don't really want to pull everything out of the media racks again
Update.....It was indeed the PAL/NTSC setting that was stopping it working.
You can see the results here
Cheers again chaps, would still like to know where the wiring diagram for it is though
Old 24th March 2015, 02:12 PM
I have a question .... i note there is an output on there .. can this be used to send the tv signal to the rear screens ?
As well as having the input for av1 to display the dvd in the front ?
