Old 30th November 2014, 10:41 AM
mark_le_b mark_le_b is offline
Default Drivers door microswitch/central locking issue
Firstly apologies if this is in the wrong section!
But, would a dodgy drivers door microswitch effect the central locking pump
I think the microswitch has an issue - sometimes the interior light works, sometimes not (as well as the courtesy light on the bottom of the door)
So when I'm driving the interior light will flicker on/off (seems to be more when I'm turning corners)
When stationary interior light seems to work ok with all the other doors (but not always with the drivers door)
Would this be the door microswitch? Would this also cause the central locking pump to cycle more than it should??
I hope the switch in the lock is the issue, because hearing the pump operate when I'm driving along is making me crazy! Door seems to click too, which is why I hope thats the culprit
Any thoughts if any of the above made sense!
Thanks
Old 1st December 2014, 07:29 AM
I have a problem with the microswitch in the passenger door where interior light and the door bottom courtesty light sometime stay on but, in my case, the door open icon shows on the DIS. I have to open/shut the door a few times to clear. The lights then function as normal. If it is the drivers door then it is likely to also affect the central locking circuits. Does the door open icon come on with yours?
Old 1st December 2014, 10:14 AM
No door open icon (which is weird) - so I wonder if it is the microswitch - it seems to be similar symptoms! driving me mad. Is this the kind of thing that dealer could pinpoint as the route cause by plugging car in?
Old 2nd December 2014, 04:56 AM
The_Laird The_Laird is online now
There's a VagCom register on this forum - if you find the nearest to you and get in touch, it'll be 'plugged in' for beer money!
Old 2nd December 2014, 05:16 AM
Thank you
Old 2nd December 2014, 09:18 AM
It's here: http://forum.a8parts.co.uk/showthread.php?t=1005&page=7
Old 2nd December 2014, 11:30 AM
Thanks, nobody in Jersey, so may have to resort to dealer
Old 2nd December 2014, 11:45 AM
Or see if there's a good VAG independant garage on Jersey
Old 2nd December 2014, 02:05 PM
or invite someone with a lead over for a holiday! haha
Old 2nd December 2014, 02:45 PM
Sounds fair, I've got a spare room :-)
