Old 5th December 2014, 02:22 PM
pwacka8 pwacka8 is offline
just doing some more investigation , do you mean option 61 battery control module or is it the part No.8E0907279E which is i think called the power control module?
2012 4.2TDI SE EXEC
Old 5th December 2014, 02:46 PM
also they would need to have connected the earth side of the jump cables to the "hexagon bar" that is above the battery to jump start it properly and not just to the positive and negative terminals of the battery (see owners manual)
Old 5th December 2014, 04:33 PM
Hello pwacka,
The log file looks like it wasn't cleared and has lots of low battery spurious faults/red herrings.
Can you charge the battery
choose autoscan in VCDS
choose the Audi A8 D3 from the popup list
Untick Use CAN only
Tick Display freeze frame (to include voltage, date and rpm)
Clear all DTCs
Try and start car
Click Start again and new post log here.
It may be worth slightly undoing a union on one of the easiest to get to injectors (17mm) and cranking, diesel should leak out in pulses.
is it cranking healthily?
Old 5th December 2014, 05:51 PM
Oli18's Avatar
Oli18 Oli18 is offline
Don't suppose anyone put petrol in by accident? Recent mistake on mine (by missus) made it behave like you described....the irony is I work for Shell.. Lol!
Audi A8/S8 D2 Flickr Group
Old 5th December 2014, 07:30 PM
Thanks for all the advcice, soupdragon , i will try it again in the morning and report back.
Im suspect about my vcds ,as people have mentioned it doesnt look like its clearing the codes properly!!
2012 4.2TDI SE EXEC
Old 5th December 2014, 09:55 PM
manca manca is offline
Oh.... that's a Clanger.....
Old 5th December 2014, 10:07 PM
Depending which version, and how old, you may have to clear the codes controller by controller.
Old 6th December 2014, 07:16 AM
Norretal's Avatar
Norretal Norretal is offline
Beat me to it........
Audi TT - 2015 - Ultra
Old 6th December 2014, 08:43 PM
Back on it today
Checked all fuses ,all ok
Recoded battery double checking my bat control module part no ,see attached pic,
Part No.4E0 910 181 C
Bat Serial- 0092S50150 ( BOSCH S5 110AH )
Selected Varta as manufacturer as Bosch wasnt listed
Then done auto scan (unticked use CAN Only)and cleared codes , tried starting , just turning over ,nothing ,allthough cranking healthily
Run auto scan again (unticked use CAN Only) and it looks like it has cleared the old codes that were on the last read.
Saturday,06,December,2014,15:37:53:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ4E77N016939 License Plate: 06 1336
Mileage: 143620km-89241mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 11 31 15 16 17 18 19 1E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 67 6C 72 76 77
VIN: WAUZZZ4E77N016939 Mileage: 143620km/89241miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 409 B HW: 4E1 907 409 A
Component: 4.2L V8TDI G000AGMª0010
Revision: --H04--- Serial number: AUX3Z0G0315682
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 23450907E2202306A91-8076
1 Fault Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 13:29:40
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Bin. Bits: 00101000
Torque: 464.1 Nm
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 S HW: 09E 927 156 B
Component: AG6 09E 4,2 TDI RdW 0010
Revision: --H01--- Serial number: 0101837
Coding: 0000001
VCID: 3365F94752C0B386591-8066
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 224B0C03FD3A2A0EA27-8077
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G0315682
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 1940
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 0
Reset counter: 9
Mileage: 143616 km
Time Indication: 0
Date: 2014.12.06
Time: 15:30:46
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 24470A1BE72E243ED0B-8071
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 A HW: 4E0 035 729 A
Component: Interfacebox H43 3450
Revision: 00000000 Serial number: 300BS077578755
Coding: 0000002
VCID: 2A5BE423850AF24EEA7-807F
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000031417
Subsystem 3 - Serial number: 0116.02.070000000100010022ÿ
Subsystem 4 - Serial number: 010022ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000114701
Coding: 0022529
VCID: 1C3732FBDF5E1CFE68B-8049
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0143121
VCID: 3663C05341B2A6AE7EF-8063
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 9
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 15:28:28
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 00000000
VCID: E5C1D71FEC949D36875-80B0
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI G000AGSª0010
Coding: 0011773
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H14 4210
Revision: 91H14421 Serial number: 0037P0G07NUP
Coding: 0431707
VCID: 275D1D179618CF26F59-8072
Subsystem 1 - Serial number: 63328RB40219F787R
Subsystem 2 - Serial number: 63428RB40219F21AJ
Subsystem 3 - Serial number: 63528RB40219F2D1N
Subsystem 4 - Serial number: 63628RB40219F211C
Subsystem 5 - Serial number: 63729RB40206046CD
Subsystem 6 - Serial number: 63829RB40206046BD
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0112141
VCID: E5C1D71F2C949D36875-80B0
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 B HW: 4E0 920 951 B
Component: KOMBIINSTR. VDO H82 0530
Revision: D04 Serial number: AUDID3G1000959
Coding: 0000413
Shop #: WSC 00414 210 91518
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 G
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3B34E3D56A62CE7A7-804F
1 Fault Found:
01407 - Flame Extinguished
000 - -
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0712581DF
Coding: F5D9DFFF70720E
VCID: ECD7A23BCF7EAC7ED8B-80B9
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H44 0350
Revision: 00044000 Serial number: AUZ5ZBG3168326
VCID: 183F2EEB2B6670DE4C3-804D
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
1 Fault Found:
01437 - Control Position not Learned
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 13:34:56
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063338
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 T HW: 4E0 919 887 L
Component: MNS ECE H48 1030
Revision: 00000000 Serial number: 364BU077640937
VCID: 3E73D87369826EEEA6F-806B
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000703100045
Coding: 0035968
VCID: 1D313FFFC44415F69F5-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 D
Component: Türsteuer.FS BRM005 0180
Coding: 0028462
VCID: 204F060BF336381EB43-8075
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 C HW: 4E0 907 289 C
Component: Komfortgeraet H09 0020
Revision: 00200009 Serial number: W040702150086
Coding: 0004317
VCID: 29591B2F800CF956E3D-807C
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 Q HW: 4E0 035 223 G
Component: DSP-High D3 H03 0110
Revision: PROD_01 Serial number: 00000000010375
Coding: 0000023
Shop #: WSC 00640 210 83262
VCID: 2B55E1278AF0EB46111-807E
2 Faults Found:
02454 - Microphone Unit (in Front Roof Module) (R164)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 10
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 13:35:03
02753 - Inside Microphone (R74)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 10
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 13:35:03
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000105411
Coding: 0010101
VCID: 1E3338F3C9420EEE86F-804B
2 Faults Found:
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 14:06:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Status: 01110100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 13:36:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 D
Component: Türsteuer.BF BRM005 0180
Coding: 0028462
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0001031
Shop #: WSC 00210 007 45725
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 224
Time Indication: 0
Freeze Frame:
Voltage: 5.59 V
Count: 61
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000006
VCID: 3D71DF7F648475F6BF5-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396BY077560494
Coding: 0000001
VCID: 2E53E833B9E29E6E36F-807B
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000001232
Shop #: WSC 00353 210 91471
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 0092S50150
Coding: 344530393135313035412056413030303932533530313530
Shop #: WSC 12345 128 00289
1 Fault Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 15:30:54
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028462
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000702050031
Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J72106G
Coding: 1020302
VCID: DCB7F2FB1FDEDCFE28B-8089
1 Fault Found:
00778 - Steering Angle Sensor (G85)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 15:30:38
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0028462
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730703110317
Coding: 0221008
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 9
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 15:10:20
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 A HW: 4F1 862 335
Component: BTA H09 0710
Revision: 00H09000 Serial number: 00000007523051
Coding: 0060001
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 143628 km
Time Indication: 0
Date: 2014.12.06
Time: 13:35:03
END
Also checked fuel supply to injectors and there is fuel while engine is cranking.
Dont know whether recoding the battery or unticking use CAN only sorted out clearing the error codes??
Still not sure if i have coded the battery properly , never done it before ,can anyone comment on how i have done it.
Thanks in advance
2012 4.2TDI SE EXEC
Old 6th December 2014, 08:44 PM
pic
Name:	Bat Coding.jpg
2012 4.2TDI SE EXEC
