For Sale and Wanted - General Posting for buying / selling your own personal non vehicle related items |
That's the one
![]() Does it then behave if you turn it down after that?
No, it doesn't matter if you turn it up or down it simply either goes silent or blasting.
Interestingly enough though, I was out for a few hours yesterday & the sound returned to normal so I wonder if it is simply to do with the cold? ....and now the aerial isn't raising ![]()
The Garage Audi A8 D2 PF - 1999 - 4.2 Quattro Sport in Silver - Bose, Blinds, S8 exhaust, FL armrests, S8 Brembo's. VW Tiguan 2.0 TDi Bluemotion 2013 - The OH's company car & general family runabout. Honda Transalp 1999 XL600 VR - My runabout Honda CX500 - The winter project 2014/15 |
It is definitely down to cold, memory in the Motorola microcontroller chip can handle about 10k write cycles, so it wears off with the time and cannot be written again. It is still writable in the warmer conditions, with the time you will need hotter and hotter conditions for it to write correctly until it will not be writable at all. The chips are available from far east fairly cheaply, I researched this couple of years ago I think they were less than $10 per piece if you bought at least 10. I believe however is that they need to be programmed with the firmware before you put it the radio as they agre general purpose microcontrollers ussed in many aplications so you will need appropriate writer and the firmware(read it from the old chip or download).You can also get them as Blaupunkt part number which I believe come ready programmed but a lot more expensive, about £60 or you can get radi repaired for about £100-120.
Edit I just opted to set the default volume at acceptable level and only rarely use volume knob when I know it is warm and should be OK.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 19th December 2014 at 12:17 PM. |
Jeez, Ainars, how do you know all this stuff?
As above:
I find with mine that when it is moved from cold it goes to loud, I turn it off and back on again and the volume has gone to the level I moved it too but I want to fix it as it makes the little one go to tears (bloody wuss) |
1. Resume last used volume 2. Use default volume setting every time it is switched on Quote:
Virgin microcontrollers that I belive need to be programmed before use :http://www.alibaba.com/trade/search?...xt=MC68HC05B32
missed this... sorry
many thanks for the information |
Stereo still available Adrian ?
