Old 17th December 2014, 05:25 PM
Two of mine started getting water behind and would make a squishy sound when pressed. One of them didn't work most of the time. This would also freeze hard under the silicone button when below freezing. One day I used a silicone spray with a straw on and jetted it into the gap while jabbing the button and then wiped off the excess. It started to work again, but recently started getting water behind so will do again.
Old 19th January 2015, 11:00 AM
solo solo is offline
I've experienced this issue on my car too. I'm new to A8 ownership, this is my first, which I've had for a few months now. The drivers door button was not responding at all and so I was contemplating total removal, etc. Then I discovered this thread, gave the WD40 thing a go and I have since had intermittent function
Then, this morning, a below zero frost meant that the button was frozen solid, they all were .
Recently I've been thinking about more WD40, to be then followed through with compressed air to blow out any residual debris, from the switch assembly.
I'm also wondering if the switch/handle assembly may have a drain hole, which over time, may have become blocked. I'll look underneath, next time I'm looking into the button issue.
Old 19th January 2015, 06:47 PM
Mine needs doing again on the front passenger side.
It is so annoying. Pushed for time to spend on the car at the moment though.
Old 21st January 2015, 04:43 PM
kele kele is offline
They are poorly designed on the pre 2010 cars. I had one go on a 2008 3.0 tdi and had an independant fix it. New handle and paint. To be honest I would just leave it now. Especially since that independant 'Audi specialist' in Stockport made a total pigs ear of it. It went back four times as the handle came off in my hand. In the end, a main dealer did it for me foc.
On my 2009 s8 both doors on the near side handle buttons have failed but they were done on audi warrantee.
Old 21st January 2015, 08:10 PM
freakszajba freakszajba is offline
Same problem here , button on rear drivers side is solid.
Its even worst , when I use any of the other buttons to lock the car it automatically unlocks.
Any advice ?
Old 5th August 2015, 10:46 AM
Duffy Duffy is offline
Are these handles sided or are they the same all round?
Thanks!
1988 Audi 90 2.2E
2011 Mercedes E250
2016 Abarth 595 Competizione
Old 5th August 2015, 10:59 AM
The handles are the same all round x3 passengers, the drivers handle has a different part number.
Matt
