Old 4th January 2015, 06:15 PM
mark_le_b mark_le_b is offline
I think I found it, should be fuse S130, a 50A fuse. I cant work out where its supposed to be in the drivers footwell on the side, or in one of the other fuse boxes. Maybe I'm being thick I cant find a fuse diagram in ElsaWin, surely there should be one?
Relay should be no. 4 in the passaenger footwell?
Will try and find fuse and/or relay
can i pull the relay and not the fuse?
Old 5th January 2015, 12:47 AM
Pulling the relay will do no harm, might throw an error but you won't damage anything.
Old 11th January 2015, 03:44 PM
I think you're onto something there! perhaps the rubber diaphragm has failed and is vibrating as it lets air out?
Its the black plastic UFO type object at the back of the engine.
Here it is in a picture I borrowed from another forum member's post as it shows the engine bay without covers.
It is easy to remove by jubilee clip or the Audi type clip, but I'm not sure if its safe to run the engine without it or with the rubber hose plugged to test if the noise stops?
Probably ok for a minute or two, as its just a sprung rubber diaphragm to let some crankcase pressure out when it builds up enough to be able to open the diaphragm.
This is how it looks inside:
http://forums.quattroworld.com/a8/threads/8649.phtml
Eureka! This is the problem, found this was the noise this afternoon
Can anybody help with a part number so I can order a new one
I assume its easy enough to change over
Thanks
Old 11th January 2015, 04:25 PM
Thanks
The part number is 077103245B. As for fitting, it is held in place by two clips. I had mine replaced a little while back and just used bog standard Jubilee clips instead of the OEM type used by Audi.
Old 11th January 2015, 04:33 PM
Great - thank you
Old 11th January 2015, 04:34 PM
Same component failed on our A6 Avant 3.0 petrol - sounded horrific but noise went away off idle. On stripping it the valve was full of crud, so be prepared to spend some time removing pipes in the vicinity and checking they're not blocked and/or squidgy from oil.
Not sure if it's the same for the '8 as was the case for the A6 but there were 2 part numbers, one being for a kit which included more bits and wasn't much different on price but included a couple of pipes - worth querying when you order
Old 11th January 2015, 05:15 PM
I will check when I order
Thanks for the advice
Old 11th January 2015, 07:44 PM
It's worth just taking it off (dead easy with the right clic-r tool) and taking it apart (very simple) and checking/cleaning it.
Mine had a tiny tear in the very edge of the diaphragm which I reckoned wasn't a problem (probably clamped between the two halves of the body) but I bought a new one eventually just in case.
Once it's cleaned it's very easy to test it works by sucking and blowing into the appropriate orifice!
Kept my old one anyway as "backup". Part number on the casing is 077 103 245 B.
Old 12th January 2015, 09:02 AM
I bought myself a pair of the right pliers to remove the clips - so shouldn't be an issue to get it off
Will take apart and have a look
I have ordered a part - but if the other one seems serviceable, will keep it as spare too
Thanks
Old 12th January 2015, 09:37 AM
Just a minor point on removal/replacement.
The tool you use is turned 180 degrees between removal and installation mode, hopefully not a huge change in angle but how much will depend on the design of the tool you have. I had a bit of a struggle to get it onto one of the clips for removal.
So, when you put it back together just decide carefully where to place the clip so that it's easy to get at for both jobs.
IIRC I removed the side pipe first then had to bend and twist a fair bit to get at the one underneath.
