Old 6th January 2015, 11:24 AM
Found a useful thread about using VCDS after a Lateral Acceleration Sensor replacement in a TT.
http://www.audiworld.com/forums/tt-m...-g200-2746174/
Matt
Old 6th January 2015, 04:26 PM
Thanks Matt that's very helpful - much appreciated
Replacement sensor on its way from A8 Parts so just a load of dismantling, reassembling and vagcomming to do!
Old 15th January 2015, 06:39 AM
Update. So the sensor is in it now works fine . However all the lights are still on the dash but on vcds the code has gone. It seems to have re set itself.
The only fault now is dtc memory of abs controller and a valves voltage supply to abs pump
Dose any one have any idea ?
The abs module was changed about 5 weeks ago and the problem was cured but now this ?
We are clueless can any one help please ?
Old 15th January 2015, 08:49 AM
I assume you did recalibrate the newly installed G200 module? It needs to between -1.5 and +1.5 m/s². And the installation was done with the battery disconnected?
Matt
Old 26th January 2015, 08:51 PM
Quick update to this - the lateral acceleration sensor was put in and scans as working correctly. It appears to have re calibrated itself without doing the esp recalibration excercise. All other codes were eliminated apart from one which was to do with DTC memory on the abs controller. A new code appeared which was confirmed today by Swindon Audi's Master-tech as being caused by a fault in my replacement abs ECU - he confirmed that all remaining dash lights should disappear once this ECU is repaired or replaced. So I am going to send it into a company called bba-reman who refurb the ECU (take it off the abs unit and just send it in on its own). For about £150 they offer a few days turn around and a lifetime warranty once they have done it. I'll report back once this is done
Old 26th January 2015, 09:51 PM
Never used them myself, but have heard good things about BBA.
