Old 4th January 2015, 01:08 PM
carmel120 carmel120 is offline
Default d3 alarm siren
hi I have a fault code for the alarm siren so I had a look under the bonnet and the siren is missing and I don't see the connecter plug does anybody no where the wiring connecter comes from.
cheers trev
Old 5th January 2015, 11:41 AM
I've replaced my siren twice, I assume you are looking at the passenger side under the scuttle panels right up against the bulkhead?.
Old 5th January 2015, 05:39 PM
ah ok found it I was looking at the drivers side.Whats the best way to remove the siren does the expansion bottle just lift up when I remove the two 10mm bolts.
cheers trev
Old 10th January 2015, 05:14 PM
Undo the bolts and lift out, I dont have anything close by the siren. Clean up the dead leaves etc. from behind it before refitting.
Old 17th January 2015, 08:50 PM
hi does any alarm siren fit a d3 the part no are the same its the letter at the end is different does this matter.
cheers trev
Old 21st January 2015, 03:59 PM
The same part is used pretty much across the Audi Range, just with a different bracket. The one I have now came from an A6 or A4, cannot remember which. There are two different sirens, the later ones tend to be have better longer lasting batteries.
Old 21st January 2015, 04:11 PM
A8 Parts, our forum sponsors (see heading) should have a good supply of them
im sure there will be a lead in the rear wing area somewhere that plugs back into it if you get one. People disconnect them as they start to go off repeatedly sometimes when the battery gets low
Old 21st January 2015, 06:13 PM
steamship steamship is online now
cheers trev
Mine came out of an A4 and cost me a tenner, but as Mannyo says, it seems to have been widely used. The VW ones might be the same, so might be worth a wander round the local scrapyard.
Old 21st January 2015, 07:25 PM
got this one on the bay
http://www.ebay.co.uk/itm/2517938197...%3AMEBIDX%3AIT
