Old 20th January 2015, 12:40 PM
How do i tell the difference between the non afs11 ect ? Do they look the same ?
Old 20th January 2015, 12:50 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I'm not 100% sure.
I've not had the chance to study both lights.
I suspect the AFSII lights would have a larger gap to allow the lens to move.
If the car is complete you can set it to Showroom mode and the lights will move when the car is not moving.
EDIT: I can take some pictures of my lights for you.
[center]
06 3.0TDI Quattro:
Options:
Old 21st January 2015, 12:37 AM
I'm not 100% sure.
You still need to turn the steering wheel to get them to move though in showroom mode
Old 21st January 2015, 06:22 AM
ScottD3's Avatar
I thought that bit was kind of obvious?
[center]
06 3.0TDI Quattro:
Options:
Old 21st January 2015, 07:02 AM
Might be to you an me but sometimes the simple things are overlooked.
Old 21st January 2015, 07:47 AM
ScottD3's Avatar
True.
Sexy lights!!
There is a post on Detailing world about adding the LED DRLs from a none AFSII light to a AFSII with out LED DRLs.
Might be of use.
[center]
06 3.0TDI Quattro:
Options:
Old 23rd January 2015, 03:08 PM
can some one tell me the Part number for the AFSII and also what on earth the Abreviation means ?
I will check tomorrow and see what my part numbers are you see .. i know i have the choice of 2009 non LED DRL but may be ASFII system and also a DRL W12 set but to be honest im leaning towards the ASFII system and il just stick a Cree bulb in and Bridge the Wires ect and have the same affect as the W12 only Brighter
Old 23rd January 2015, 03:11 PM
change pattern with speed and move when the steering is moved and extra lights when cornering.
Can i have the part number if anyone has it and il see if i can get them ones instead
https://www.youtube.com/watch?v=Cu_0G9QtAMo
is it as per Scotts Link in another thread ?
Old 23rd January 2015, 03:17 PM
Also is it a plug and play and just re code on Vag com for me i have Xenon with Halogen Main beam ? will the wiring be the same do you think ?
thanks Guy's
Old 23rd January 2015, 08:09 PM
PRetty sure audiforums.us has a few threads on headlight swaps. Some need a bit of fiddling with the wiring, some are plug and play. I think it depends on what you had to start with.
