Old 1st July 2013, 07:15 PM
moraym moraym is offline
Default MMI Update from version 03.5.00324
Hi
I'm away to update my MMI from the version referenced in the title (this was displayed on MMI screen when I checked version) and am looking for a bit of reassurance & guidance before I start.
I've already got the 4L0 998 961 disc but it won't update using this - I'm assuming I need some or all of the earlier update discs.
I've ordered 4E0 906 961 L, 4E0 906 961 T, 4E0 906 961 AA & 4F0 906 961 AB from the dealer. I believe this gives me the full compliment of available discs (used this website for reference : http://www.audi-resource.com/mmifwver.php). Didn't mind paying for them - I think it cost about a tenner for the whole lot.
Does anyone know which disc I should be starting from, or is the MMI 'smart' enough to know which ones to not update from - i.e. if it only needs 4F0 906 961 AB & then 4L0 998 961 will it ignore attempts to update from earlier discs ?
Any help greatly appreciated
Thanks
1997 D2 S8 (Nogaro Blue)
2004 D3 A8 4.2 Quattro (Nordlich Blue)
2004 D3 A8 4.2 Quattro (Nordlich Blue) - Yes, another one !!
ALL GONE
Old 4th August 2013, 03:07 PM
Just a progress report on the MMI update;
System steadfastly refused to update with the discs I had......
.......turned out I was missing one update disc - 4E0 906 961 H.
Once I got a hold of that one the update went fine. I know at some point I could probably have missed out a couple of discs and gone straight to the latest one (4L0 998 961) but I erred on the side of caution and patiently ran through all 5 of them one by one - granted it took about 2-1/2hrs, but I now have 5570 and have my AMI system up & running.
Very happy man !!
ALL GONE
Old 16th February 2015, 08:27 AM
zed_thirteen's Avatar
zed_thirteen zed_thirteen is offline
Hi all,
I've also purchased 4L0 998 961 3 CD-ROM set from my main dealer only to find out that I need 4E0 906 961 H.
All of the download links I've found are no longer working. Can anyone help?
My 2003 D3 is still at 290 (02.9.0)
Regards
David
Old 16th February 2015, 09:13 AM
Not sure if it works as I am at work, but have this in my bookmarks..
http://www.torrentreactor.net/torren...-998-961-0S-0L Install utorrent.app and click the horseshoe magnet icon.
Old 16th February 2015, 09:23 AM
Thanks but I already have 4L0-998-961 thanks. Looking for 4E0-906-961.
Besides, I'm having real trouble getting to torrents through Sky these days!
Old 16th February 2015, 01:47 PM
Virgin is reporting receipt of a High Court Order instructing them to block this site.
No fun anymore.
All the money makers are in control
Old 16th February 2015, 02:43 PM
It's online here once you register.
http://www.audi-resource.com/mmimenu.php
Or you can buy the original CD from TPS for about £6
Matt
Old 16th February 2015, 05:58 PM
I can confirm the download from there works perfectly fine, since the source of the ISO is me. It took me quiet a lot of searching to track down that disc as I was in the same boat and needed to update to 1100 before 5570. The site is operated by an A8parts forum member.
Once you get to 1100 you can go straight to the three CDs for 5570 with no need to go through the others incrementally.
Old 16th February 2015, 06:13 PM
Burnzybubbles's Avatar
I tried audi resource for that disc and had no luck, in the end I got it off eBay as I didn't have the time to go into the dealers two weeks on the trot and I was getting impatient,
Old 16th February 2015, 06:15 PM
Originally Posted by mannyo View Post
I can confirm the download from there works ....
The audi-resource links go to the file sharing site but says file not found.
There are various links on this thread...
http://gpsunderground.com/forum/audi...-5570-a-4.html
or you could try posting a message on it requesting someone to supply it.
