Old 6th January 2014, 11:15 AM
For the 110Ah, I used 000915105AK on mine.
(Now have a 95Ah AGM, I used 000915105CE )
Old 11th January 2014, 11:12 AM
audifin audifin is offline
Originally Posted by mannyo View Post
Serial number can be anything. When I did mine, I just added one to the last digit and saved that. What was the previous battery, if it was a 110AH you may get away with leaving the part number, just select Varta from the dropdown. Just altering the serial is enough to get the battery monitor relearning parameters.
Thank you for advice, battery now coded
Old 19th February 2015, 04:48 PM
My Indie was trying to remap the engine and failed disastrously 'cos the battery voltage dropped to 10.7 when the radiator fans kicked in. ECU file corrupted. Oh Bummer!!
Fitted new battery, ECU reloaded to factory default?? Then remapped and the car now has a low flying licence.
Used this thread to register the new battery, just changed the last digit as suggested earlier, success.
Thanks Guys, where would I be without you.
Attempted to clear all the faults with VCDS, shifted a few but still left some old ones from before I had the motor. I'm gonna have to learn more about VCDS
Old 19th February 2015, 05:22 PM
You should never do any remapping without a bench supplied constant 12v power supply. That was bad luck though lol. Bet he wished he had stayed in bed that day !! Expensive mistake !!
Old 19th February 2015, 06:32 PM
When my Guy realised that the voltage was low, apparently 11.8 is too low, he connected a large starter charger that landed up delivering a constant 45 amps and the voltage lifted to 11.4. He then put on jump leads from a new transit as well as the charger and we upped to 11.6 volts. Very strange.
Waited for a new battery, installed it and we were way over 12, connected the big charger and then sorted the mess.
Like you said, perhaps he should have stayed in bed. I had noticed that she was not turning over as usual on cold mornings. The new battery has resolved this.
Old 19th February 2015, 08:20 PM
Cyclone Cyclone is offline
Hi, who was the indie who did your remap?
Old 19th February 2015, 08:24 PM
Battery on its own car off should be around or slightly over 12,5 ideally, although voltage alone doesn't tell the whole story. I have a conductance tester (Solar BA7) which is as good at testing batteries for a small outlay (no method is singularly perfect) as it gets presently.
Old 19th February 2015, 08:29 PM
Did he connect it in series or parallel - always the former if you are looking to jump start to get max juice, never battery to battery.
Old 19th February 2015, 09:30 PM
If we did connect the external supply in series with the vehicle battery then we would be applying 24 volts to the electronics.
My battery problem was due to a dead cell. A drop test proved this after we had removed it from the car.
Old 19th February 2015, 10:07 PM
My point was probably misplaced in this post. I would agree you wouldn't want to re-flash anything with over voltage, however, for jumpstarting purposes, it is best to connect in series. The voltage regulator will handle it and as one battery is sub 12 you are not at 24v (but even at 24v no problem). The reality is ECUs etc very rarely get fried if at-all and is more of a theoretical based problem or in the fractional percentages.
