Go Back   A8 Parts Forum > A8 D4 > D4 - Wheels and Tyres
D4 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here
Old 20th February 2015, 03:05 PM
nath nath is offline
Default tyre pressures
guys just wanted an idea of what tyre pressures you run and on what size wheels and tyres
unfortunately the sticker is worn on the inside of my door so cannot see what pressures should be , cant find it in the book either
im running 265 40 20
Old 20th February 2015, 03:37 PM
Conquistador's Avatar
If you're on factory wheels then you can use a search like this to find the manufacturer's advised pressures:
http://www.kwik-fit.com/tyre-pressure-search.asp
If you're on aftermarket rims and tyres, then it's really a case of trial and error to see what pressure feels best or if you notice any wear either down the middle of the tread or on the outside/inside of the tyres.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 20th February 2015, 10:42 PM
cheers mate
much appreciated
