Old 26th February 2015, 08:01 AM
Urbtree Urbtree is offline
Default center dash computer gone off.
Anybody know how I go about fixing it.
Was working fine till our long journey the other day..
2000 A8 D2 2.8 none Quattro
1990 Lada Niva Cossack Jacked
2008 Transit 140
www.tyresbarrow.co.uk
Old 26th February 2015, 08:04 AM
Push the button under the right hand stalk, maybe you switched it off by accident ?
Old 26th February 2015, 08:52 AM
Dave McB Dave McB is offline
Mine doesn't come on properly in cold weather until the car warms up a bit - could that be the cause?
Old 26th February 2015, 10:25 AM
I only found this function a few weeks back but the buttun referred to by IT cycles the DIS through satnav directions (when navigation screen is selected on RNS), computer read out of mpg etc and a blank screen. Hope that that's the issue and nothing more serious.
Old 26th February 2015, 10:50 AM
I suffer from both of the above:
1. DIS is blank or very faint in cold weather until it warms up
2. Only discovered in the last year or so what the button on the underside of the right-hand stalk does. Very useful now though.
Old 26th February 2015, 11:01 AM
Aren't these 2 different buttons? One (on the left stalk IIRC) cycles the DIS display and the one underneath the right stalk turns it on and off. I've turned it off by mistake a couple of times.
Old 26th February 2015, 11:04 AM
There's 2 buttons on the end of the right stalk that cycles through the available display functions - just a rocker switch
The one underneath the right stalk will reset the trip computer settings on each display you scroll through IF you hold it down. If you press and release, it switches the display off which can get a bit confusing!
Mine will also be a bit dim on cold start sometimes - usually wakes up fully after a couple of minutes
Left stalk only has the 'set'/increase speed function on the end of the stalk (could be decrease speed as car isn't out to check!)
Old 26th February 2015, 11:06 AM
Not on mine. It cycles through Nav, computer and blank.
The up/down switch on the end cycles the trip computer options.
Right stalk.
I think a long press resets the computer which is why I left it alone for so many years; this is a quick prod.
Old 28th February 2015, 02:37 PM
Yep your all spot on. I was holding the button to long
I blame the missus.
Have to say I was having nightmares when I bought this car about fixing costs but so far its all been relatively cheap or free.
2008 Transit 140
