Old 6th March 2015, 06:20 AM
mannyo mannyo is offline
The ebay cable will never work, not only is it supplied with such an antique version of the software. Version 409.1 was released in 2004 and has no support for the A8 D3.
The second one is a fake cable, which may or may not work, and you'll be forever stuck on the hacked software supplied. Another headache is that the PC with the software installed must never go on the internet again, because VCDS will fail a license check and the cable could be erased by VCDS. VCDS has a background update process that checks back to base for known hacked cables and invalidates any found.
I've had a fake cable before, keeping it working was a lot of hassle. The cable came with instructions on how to fix it when it failed, but you must be very proficient in computers and IT and soldering to follow the instructions.
Buy the proper cable from a UK distributor (Genden, Ilexa etc.) or direct from Ross-tech.
Manny
Past
