I would heed caution doing the tops unless vital as the pinch bolt can be a royal pita ( my s8 had Alu upright so rust weld not present) and cld turn it into a major job if things don't go according to plan.
Even so beware and unless they have Audi experience they will equally be unaware. If they are properly stuck the whole upright will need to be removed from the car and or possibly replaced if removing the pinch bolt is impossible or damage is done to it during the process. All of which could, I say could as you may be fine but could rack up a hefty bill. Some bolts I have removed are fine (my old s8) then have done them on a4 b5s and took some industrial action to remove.
Thanks.
![]() I might tell to leave the top ones in that case, if they look like they don't need replacing. Just to be clear, assuming I've got the right diagram here, which ones are we talking about?: ![]()
10 and 8. If it aint broke dont fix it sort of thing.
The pinch bolt is 25a in the diagram. IF you have an S8 it will have ALu upright (for weight saving) and you will not have a problem removing it. Only an issue with the steel ones. I also have no idea how to make the picture appear not as a thumbnail ?! Last edited by Architex_mA8tey; 7th March 2015 at 07:21 PM. |
You can always use heat to try and free them up or drill them out if that does not help, no need to replace the whole hub.
Mine is aluminium and is 3.0 TDI - I thought all D3 had aluminium.
They were very stuck in due to galvanic corrosion of the dissimilar metals + salt. Most of the bolt's length is plain (not threaded) shank and after shearing the head off, I was able to knock it in a fair way with an air chisel. I then drilled most of it out which made it reed shape. The air chisel moving it made enough threads stick out the end where the nut was - to enable a big washer and two good new nuts to be put on with lots of grease. What I could then do was to righten the two nuts against the washer - this pulled the rest of the bolt out. Aluminium didn't seem damaged. Don't heat the aluminium with a torch like you would steel as it may melt or weaken it. This must have taken a few days though as I was searching google, going to work and buying tools and new nuts etc. If I had the facilities of a commercial workshop at the first sign of stubbornness, I would remove the whole strut but in doing so you may as well change all upper and lower. But not having these, if I was to do it myself again, I would use the drill much earlier on as that was the turning point of it budging. New parts and bolts were slavered in waxoyl type spray. Last edited by snapdragon; 8th March 2015 at 11:52 AM. |
There is a special VAG tool for doing these bolts. The other workshop tool out there is like wrapping a flexible kettle element around the top of the hub, which heats it to huge temperature and expands the outer casing and breaks the bond. I have not used one or seen it in action but have heard they are effective from one source, obviously same idea as heat which is the 1st thing to try imo. Last edited by brasiliangringo; 8th March 2015 at 10:35 AM. |
A lot of garages have some kind of localised freezing kit as well, to make the bolt contract more relative to the hub. Mine on my D2 were done using that method and both sides were done in an hour (just upper 4)
#30
Left click on this attachment:-
How 2 Do It Enlarge a Thumbnail.pdf Click the "OK" in the "Open With" box, (this will use Adobe to display the attachment). You should, if I have done something correct for once, learn how to enlarge the picture!!! Sorry to all those who already know this sort of thing, and all the complicated short cuts, but I try to remember that there is always someone out there who needs help. ![]()
