Old 17th January 2010, 04:54 PM
Hi tonyt102,
Welcome to the premier A/S 8 forum and the joy of owning what is a lotta mota for your £.
Ben of AV Performance may be around shortly but I can guess what he may say.
As they weren't a Audi specialist it is unlikely they had the specialist tools for doing a cam belt change. It can be done without them but the chances of error are significantly higher. I would suspect that there is some misalignment in there somewhere which is manifesting itself as a lumpy idle.
Do you have VagCom or does your garage? Check out the error codes.
I see you are up in Cleveland. There may be a forum member that will do a VagCom scan for you nearby.
Read up on the fanbelt change here . Being a 99 it could be a 32 Valve or a 40 Valve. procedure for a 40 valve is different.
Hope you get it sorted.
Check out the A8oc and maube we will see you at one of the events.
Also if you need bits then the forum sponsors are the best suppliers in the UK. A8 Parts.
