Old 16th December 2014, 08:01 AM
Not sure how you do it PF, is it not in the drivers manual?
On FL it's the DIS menu controlled via the button/knob in the cupholder tray near the handbrake (never did get that!), which obviously isn't there PF.
If it's via VCDS, so be it, you only have to do it once after all and it's set.
Where exactly is your receiver?
Old 16th December 2014, 01:29 PM
>> I got in it Sunday night was display the time (+1 plus)
>> and also the and symbol... whaooo.... great....
This is great. Does it mean that on PF you don't have to fiddle with adaptation channel?
I can't help with shifting the clock one hour though. On FL it is done via the same clock menu. You can only add/subtract hours in the radio controlled clock mode in the clock menu. You can't change minutes or date in this mode. Only hours. I'm sure the + and the - buttons on the cluster will do the same. Perhaps you need to long press them... I never tried though...
You're probably the first one in the UK who has fitted it to the PF A8.
You need to blaze the trail to understand how to shift it one hour.
Good luck
Old 16th December 2014, 01:40 PM
There is no coding for radio controlled clock mentioned in ElsaWin and nothing about adjusting radio controlled clock in users manual I guess you have already tried the usual way of holding down both HR and MIN buttons pressed down at the same time for 2- 3 seconds like you do when normally adjusting clock?
Old 28th March 2015, 01:59 PM
OK, put mine in today and placed the receiver in the same spot as HPsauce. But I can't seem to get the hang of the VCDS coding (first time I've tried doing anything other than a scan. Where do I find 'channel 19'?
Old 28th March 2015, 02:02 PM
From here: http://www.vagcom.org/modifications/...trolled-clock/
(I think that's in instruments)
VAGCOM / VCDS changes
go to module 17, adaption 10, channel 19:
xxxx0 = disabled radio controlled clock
xxxx1 = enabled radio controlled clock
so change the last number to 1.
Old 28th March 2015, 02:50 PM
Thanks, got it. How long before I should expect to see the little radio mast icon?
Old 28th March 2015, 02:52 PM
Tomorrow, if you're lucky. Should pick up summer time.
You can fool it into checking earlier than the normal overnight process, but probably pointless, today of all days.
(Someone worked out the logic, it's either earlier in this thread or linked to it. I fooled it just out of interest)
Old 28th March 2015, 03:47 PM
Set the clock to 2.50am and then lock and leave the car for an hour or 2 - should have sorted itself out by then if you keep disturbing it then it won't sync and the car needs to be shut down
When it's set the date will be correct but the time will be on mainland Europe so you then try setting the time manually and can correct the hour, but no other settings.
Be quick about it and come tomorrow morning it will have reset for daylight saving time automatically
The little mast symbol will always display assuming there's no failed time sync in normal use - mine works in the factory position even though it's always garaged when it's checking the time
Old 28th March 2015, 04:13 PM
Just to clarify, you set the hour offset (once it's got the radio symbol) using the menu control beside the handbrake.
Old 28th March 2015, 06:59 PM
Jim, you can find some substance on page 8 of this thread:
http://forum.a8parts.co.uk/showthread.php?t=6843&page=8
