Old 30th March 2015, 01:06 PM
Here's some piccies of the knee panel attachment points.
Thanks again for those, I've now finally worked out what the puzzling "debris" is that I have from the bottom-left fixing.
Again, I blame the carphone fitter, looks like he used the wrong clip, which doesn't fit the M5 bolt properly, and is now partly missing (snapped off).
I've worked out that they're called "speed clips" so have ordered the correct type and will make a small bracket to go onto that ventilation duct to secure that corner of the knee panel as well.
Old 1st April 2015, 02:51 PM
Here's a comparison of your OEM fixing and my "reconstruction". Close enough to the right place I think.
I'm now making a bracket for the bottom left corner, from a blanking plate from the back of a PC, to fix to that square downward vent. Nearly done.
ID:	10433   Click image for larger version
Old 1st April 2015, 03:28 PM
And this is it. Wasn't that easy to line up when refitting, but the panel is now back on with all five fixings holding it securely in place.
Next time I have the panel off I'll adjust the way the bracket is secured (speed clip and screw) to the ventilation duct to improve alignment.
The metal bracket is stronger, though a similar length, compared to the OEM plastic one (removed by me) on the transmission panel.
Edit: Better picture of bracket added; just missing a non-slip washer where it is fixed to the plastic vent.
ID:	10435   Click image for larger version
Last edited by HPsauce; 10th February 2017 at 03:38 PM. Reason: Additional close-up picture.
Old 1st April 2015, 04:10 PM
Now that's determination!
Old 1st April 2015, 04:34 PM
Didn't take that long Jim and it's better than the original.
Your pictures helped too. How's the radio clock?
Old 1st April 2015, 07:35 PM
Still nothing on the radio clock.
Old 1st April 2015, 08:08 PM
Plugged in securely, coded via VCDS......
I must admit, when first "playing" with mine I ran the cable up the right side of the dash so that it sat on top (just) before fixing it where it is now.
Old 2nd April 2015, 04:42 AM
Gonna have to have another look with that knee panel off again
Stop Press! See here: http://forum.a8parts.co.uk/showthrea...1703#post91703
Old 13th October 2016, 10:08 AM
Zip's Avatar
Zip Zip is offline
Angry
My broken fixing. This is what I'm dealing with. I think I'll try and epoxy a small panel behind what you can see. I'll locate the retaining lug first.
Old 13th October 2016, 10:28 AM
Yup, mine was virtually identical. I cut off some of the top layer of soft plastic material and then screwed/glued a strip of tough plastic to the fibre backing.
Think I just used very short self-tapping screws, but something with a fixing behind would be better; was plenty strong enough.
See rather blurry picture posted earlier in this thread: http://forum.a8parts.co.uk/showpost....4&postcount=12
