Old 22nd March 2015, 10:44 AM
But if you don't buy the PDC control unit - then if you select reverse won't the parking PDC graphics cover up your camera picture going in via AUX-in.
I have a genuine Audi RVC camera in the house, but don't really wan't to spend even more money on a new boot microswitch handle and number plate light strip + getting it painted. So might try dremelling a square aperture for it in the existing handle.
Wist I'd never started this retrofit - turning out to be too expensive.
Old 22nd March 2015, 11:28 AM
Oh God, nothing is easy.
I'll put it all back in and try putting it in reverse.
I'll let you know on this thread, I was having a chill day
Old 22nd March 2015, 06:25 PM
Tried it and it worked OK.
So I have now fitted it and working via Aux 2 on the analogue TV Tuner.
Only one set of lines, the ones from the camera.
I had to dremel the boot lid handle/number plate light fixing. Started with the handle still attached, and filed the camera/number plate light plastic box to make it fit. Managed to get it in but on looking closer spotted that with a bit more hacking it would go in just that little bit better.
Took the handle off the car and went on the bench with it and dremeled away at the back. Took a bit longer, and a little bit more filing on the camera box but it went in like made for the job.
The resultant picture is a degree or two off centre and SWMBO is complaining that it is confusing, but she said that years ago when I forced her to reverse using mirrors instead of twisting round and peering through the back window.
I like it, and we have a good colour picture. It works for me but I'm used to 12 metre long buses without cameras. To be honest the very slight misalignment is not worth the hassle of stripping it all down again.
Last edited by tc4332; 24th March 2015 at 09:04 AM. Reason: Just realised that I had not fully answered your comments.
Old 25th March 2015, 02:39 AM
mcs's Avatar
mcs mcs is offline
I am going to try a graphic interface between the screen and the screen control unit. Someone locally makes a unit fairly cheaply (100 pounds or so) that will do it and cut the MMI feed when the car is reversing.
I have just needed a camera. What exact one did you get that replaces a license plate lamp?
Mike
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 25th March 2015, 02:43 PM
Mike
I may be wrong but please double check the unit is LVDS as I have read on other sites.....
The MMI Control head take an LVDS video in - not composite.
The RVC unit outputs LVDS .
The TV unit outputs LVDS but the AUX in are composite.
Old 25th March 2015, 06:32 PM
The underlined words in the following text are links. Left click on them and your browser should open up another page.
I used this camera:-
CAMERA
I also bought from the same supplier:-
Tx/Rx Pair
When ordering the camera remember to select the PAL version. The NTSC one would work but you would have to change the MMI setting on the Aux channel you use. This camera worked out of the box without any faults.
I used the Tx/Rx to save running a video cable from the boot lid to the main body. There is also the possibility that I will purchase a CAR VIDEO INTERFACE or an X-CarLinK in the future to automate switching the MMI to reverse camera view on engaging the "Going Backwards Gear".
Any problems just ask.
Last edited by tc4332; 25th March 2015 at 06:38 PM. Reason: Checking that the links work as intended
Old 25th March 2015, 06:43 PM
The LVDS that some people are talking about is when you are connecting direct to the MMI.
Because I have connected via the now otherwise redundant analogue TV Tuner the camera output can be just composite using a yellow plug/socket that is already fitted. Just plug and play.
Old 7th April 2015, 07:55 PM
Right Chaps,
I managed to buy the X-Carlink, the seller knocked £50 off for me 'cos I phoned him and had a nice chat. The manufacturer has done some updates, both hardware and software. It now does all sorts of video to the MMI screen and can pass audio to the sound system. I only want it for automating the reverse camera operation. The supplier said that it might now work with my Chinese PAL camera, and yes it did.
Now fully fitted and working really well.
Camera and transmitter/receiver pair as above.
Camera and transmitter in the boot lid, both powered from reverse light supply. The LEDs in the camera body powered by number plate light supply.
X-Carlink powered by a permanent supply and by an ignition switched supply. It also needs a reverse supply, this I took from the reverse light supply by tapping into the loom in the left boot space and running the wire through the car to behind the glove box where the X-Carlink is located. The receiver for the camera transmitter is also located there and is supplied by the reverse supply.
SWMBO has not inspected it yet, but she will give it a good pass mark, really good colour picture, no interference and it switches on automatically. Whatever sound is playing carries on, only the video is replaced by the rear view.
Engaging the backing up gear just does it all for me.
Final cost just over £200.
Last edited by tc4332; 8th April 2015 at 08:53 AM. Reason: Spelling mistake, Teacher belted me!
