Old 8th April 2015, 08:24 AM
The_Laird The_Laird is online now
Ranj
If you run a search than you'll fine some very detailed write ups on this (I'll have a look when I get a moment), but the current wisdom seems to be that you remove the carpet/trim panel from each side of the transmission tunnel and then remove the drain tubes (they're orange) and wash them out.
Poking stuff up the tubes is likely to damage them (as I think Brian found out the hard way!).
