Old 9th April 2015, 06:14 PM
Fast at Fast at is offline
Default Glove box
Can't get my glove box to open any ideas? Thanks
Old 9th April 2015, 06:54 PM
There's a Bowden cable that runs from the release button to the release catch which IIRC is somewhere right up at the top/back of the section that swings out.
Try pressing very firmly in/up on the front of the box while pressing the button in case the catch is somewhat jammed.
Otherwise I suspect it will need brute force to break the catch and release it.
Once open the whole thing can be taken out fairly easily for repair/replacement. I've had mine out a few times for various jobs, including replacing the light bulb - easiest way to do it believe it or not!
Old 10th April 2015, 06:04 AM
Thanks I'll give it ago
Old 10th April 2015, 04:20 PM
Jimbo's Avatar
Jimbo Jimbo is offline
Try after pressing the release button, put your hand under the glove box closer to the left hand side and gently pull towards you. Works for me when It sometimes does not open with the button.
James
Old 11th April 2015, 10:32 PM
goldsax goldsax is offline
has a similar problem today.
i had to open passenger door and pull glove box door forward from the side.
the glove compartment seems to be catching/rubbing on the transmission tunnel trim.
will readjust tunnel trim tomorrow.
