Old 14th April 2015, 10:31 PM
centurion centurion is offline
Default Boot opening/closing
i'm on a mission to close couple intermittent issues on my car and electric boot is currently on the agenda...
Issue:
- struggles to open up via keyfob. I can see that it pops up [by an inch or so] and then it cannot open up... few seconds later is shuts.
- i tried by going round the back and it does indeed work but needs some manual effort to lift off and it would then go all the way
- now closing is more of a problem... 8/10 times when el. button is selected just above the latch mechanism it does get a signal but fails to close.
i checked in VCDS for any issues and haven't found any... all hinges etc had been oiled using Lithium so i guess it could be down to the motor. Any suggestions?
Old 14th April 2015, 10:41 PM
The clutch is worn and slipping on your auto boot motor - you have a couple of options - either buy a new or second hand boot motor and replace it or take the motor out and it can be disassembled and the clutch can be encouraged to grip more by sprinkling some powdered violin rosin over the clutch plates to help it grip then put it all back together and voila! (Or should that be VIOLA lol)
Old 14th April 2015, 11:51 PM
cheers ... any suggestions where to get the rosin from?
also where could i possibly get the [second hand] motor from too?
Old 15th April 2015, 06:11 AM
The rosin can be bought on eBay for £2-3 for a rectangular block in a plastic holder. Just scrape some powder off it onto the clutch with a sharp knife
Second hand motor may be available via our forum sponsor (details on the header) or if they don't have one available then get the part number from ETKA or someone on here and search eBay for one
Old 15th April 2015, 06:54 AM
kele kele is offline
I had a similar issue to that you describe on mine. The dealer fitted a mod (2 plastic bits each side of the interior lid). Could be same issue but not nessasarily. I will post some pictures at the weekend.... Although on mine there was no issue closing, I have to add.
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 16th April 2015, 12:53 AM
mcs's Avatar
mcs mcs is offline
Take the tools out of the bootlid and see what happens.
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 16th April 2015, 09:40 AM
You can also try replacing the boot struts, easy to access and relatively cheap and will give it a bit more spring - often its enough to help a tired motor cope with age
Old 16th April 2015, 10:03 PM
i just did another scan today and got the following,
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601180371
Coding: 0004861
Shop #: WSC 02313 785 00200
VCID: 285F1E2B9B06C05EFC3-807D
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
1 Fault Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 228806 km
Time Indication: 0
Date: 2015.04.16
Time: 09:22:42
couple things - can the clutch [inside the motor mechanism] be replaced? If so, what is the correct part no. and could it be ordered?
In the meantime i will try the trick with violin resin and see how it goes
Old 17th April 2015, 10:35 AM
Only bodge it or replace the whole unit, they don't sell bits for it.
The other thing worth trying is make sure the hinges are lubed and free moving.
Also there is reports of the hinges getting bent/distorted so worth having a good look over it all before you go splashing cash on a replacement.
Old 17th April 2015, 01:28 PM
audifin audifin is offline
It would be very easy to replace the clutch, IF Audi sold the parts... but they don't. I've done a few of these and I'm yet to see a "tired" motor, it's always been the clutch slipping.
I fixed mine with violin rosin for about a year and 10k miles ago, still working fine. If it stops working I'll just do it again, it's a 20 minute job after you've done it once
