hi,
i did several scans on VCDS and R138 pops up regularly. Now i was keen to get keyless entry sorted out on mine and did read some of the posts related to it. I removed/disconnected the antenna but that did not fix anything so to speak... Keyless entry still does not work, i cannot lock the car via lock button on the driver's door handle [nor on any other] etc. Something i tried the other day as well is to put in a key in the lock and select Start button and was presented with 'key not recognised' or something along those lines. A weird thing is that i can stop the engine using the Stop option which does not hold for Start?! Any hints? Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F0383728 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: D8BFEEEB6BE630DE0C3-808D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 1 Fault Found: 00183 - Interior Access/Start Authorization Antenna 1 (R138) 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 4 Fault Frequency: 0 Reset counter: 217 Mileage: 228752 km Time Indication: 0 Date: 2015.04.14 Time: 16:10:02 Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F0383728 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: D8BFEEEB6BE630DE0C3-808D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 1 Fault Found: 00183 - Interior Access/Start Authorization Antenna 1 (R138) 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 4 Fault Frequency: 0 Reset counter: 217 Mileage: 228752 km Time Indication: 0 Date: 2015.04.14 Time: 16:10:02 |
