Old 20th April 2015, 02:13 PM
centurion centurion is offline
Default 4.2 TDI - engine diagram
hi,
has anyone got any hints where EGR and MAF is/are on 4.2 TDI?
and also what are the part no.'s for those?
Old 20th April 2015, 02:54 PM
Try manual 10
http://forum.a8parts.co.uk/showthread.php?t=9347
Old 26th April 2015, 07:00 PM
cheers... it looks like that one of the two MAF's is playing up so will look to replace both in due course.
In the meantime to be absolutely sure it is indeed MAF, [stupid Q] if I was to disconnect them both could I start the car? or one would have to start it and then disconnect etc.
also, any suggestion of where to source the part/s?
Thanks.
Old 26th April 2015, 07:02 PM
As far as I am aware the engines will run on a default map with them disconnected. Can't do any harm to try, you will no doubt have a mil light on and faults to clear after the fact but I'm sure that's the least of your concerns
Old 26th April 2015, 07:53 PM
cheers... on that note off to have some fun in the back yard ... comments to follow.
Q: is it worth changing the air filter [changed 6K ago] as I found lot of sand/small stones and all sort of rubbish in both housings (4.2 TDI engine)?
