Old 21st April 2015, 09:54 AM
Default Oil Leak
Over the weekend I noticed tiny patch of oil on the undertray. There are traces of oil on the alternator. Visual inspection was difficult but the source will be something around the oil filter which is above the alternator. Hopefully it's not the oil filter housing or oil cooler...
I took one photo by removing the drivers side fog light grill where you can see the alternator.
As the air filter box and ducting is roughly above the oil filter housing, will I get a better look if I remove these?
Also, is this a known leaky area on the V8's?
ID:	10516   Click image for larger version
Matt
Old 21st April 2015, 10:00 AM
Could say Matt, but your welcome to borrow my Borescope inspection camera you thought it would help.
Old 21st April 2015, 10:33 AM
Many thanks for the offer Del I'll send you a PM should I need it.
I found this useful video of a filter change and he removed the air box for access, so it should give a better look as to the source. I'll probably do this friday or the weekend.
https://www.youtube.com/watch?v=brRlvtqamIQ
Matt
