Old 15th May 2015, 11:37 AM
Default Front anti-roll bar C links?
As far as I can tell there's no Meyle HD option for these (although there is for the coupling links) which I'm assuming is because you don't really want additional stiffness in the joints.
OEM or aftermarket option?
OEM is £42 each. Meyle non-HD are half that
I've got no evidence they've ever been changed so if they've lasted 13 years/62k miles there's probably no reason to buy anything other than OEM but interested in views before I order anything.
It's in for a service today, but they can't get the parts today anyway.
Old 15th May 2015, 11:54 AM
I have changed them with aftermarket items several times on different Audis, they do not last long. There was earlier version with ball joints instead of bushes on early cars but those have been discontinued and superseded with bush versions. I would prefer older version with ball joints or harder bushes and longer lasting myself. Only thing is making front harder could make car understeer even more so might need to make rear arb bushes harder as well. Anyhow next time I think I will give a go poly bushes. http://www.powerflex.co.uk/road-seri...Bush/1997.html
Old 15th May 2015, 12:25 PM
Allgerman Parts have the lemforder ones in stock
http://www.allgermanparts.co.uk/prod...y?path=292_311
Shirish: 2001 S8
Old 9th August 2015, 08:22 AM
I got the lemforder version from euro car parts and they where the same as ones I pulled off the car, but with the Audi logo and part numbers machined off, superb quality very well made cheap and easy to change. Recommended
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 9th August 2015, 04:37 PM
I forgot to update this thread! Ended up buying OEM from TPS. The ones I pulled off the car were OEM with 2002 date stamp, so appears they were the originals!
Useful to know the ECP ones appear decent
Old 9th August 2015, 06:49 PM
arent Lemforder considered 'OEM' ?
In the same way TRW are?
Be interested to who manufactured your TPS parts
Shirish: 2001 S8
Old 9th August 2015, 07:24 PM
TPS is owned by the uk vw/audi importer, so only sells genuine parts
There are many pattern parts advertised with some inference that they are 'oem' but in this day and age of Internet shopping it's incredibly difficult to know what you're getting before it turns up.
There have been dodgy TRW branded parts,especially suspension joints, where the castings are very rough compared to genuine oem parts
Old 9th August 2015, 07:41 PM
Thanks for that.
I had some TRW and Lemforder lower front control arms fitted recently and now have a shimmy now just above motorway speeds (not coming through the steering wheel) Pretty frustrating after the amount of money spent, so will check if the parts are genuine TRW and Lemforder.
Shirish: 2001 S8
Old 13th August 2015, 07:36 AM
First suspect would be alignment after the control arm replacement. It is recommended that full 4 wheel alignment is undertaken after such a job and including "s" measurement. See thread and stickies.
Old 13th August 2015, 08:57 AM
only oem.
simples.
