Originally Posted by daviesbike
Could you use a lipo or is the balance charging an issue.. ? I'm sure you use lipo in your RC jet ?
Lipo are normally 3.6 or 3.7V so it's hard to get close to 12V its either 10.8-11.1V if using 3 cells in series or 14.4-14.8V if using 4. LiFePO4 are 3.2V so using 4 you get a lot closer with 12.8V compared to 12.6V on regular lead acid battery.
