Old 9th June 2015, 02:59 PM
oldnick oldnick is offline
Ah yes, that's what we were trying to do
Did he come back with his BS? I dont think he posted up anything after asking how he would know what box he had fitted.
he said he was going to visit the ZF specialist yesterday , maybe he has given up in despair !
Old 9th June 2015, 06:42 PM
sssam sssam is offline
Hi all - still here - thanks for all the info, thread has exploded! I got onto Vanmatic (ZF centre) yesterday and booked it in for week after next as I'm away next week. Though I then spoke in more detail to my mechanic today and he said they followed the full procedure to a T - level car, monitoring temp, checking level etc. Used the genuine oil and correct filter. His explanation as to why it is worse now than before is that the filter was so clogged that it was holding oil pressure in the box. The fault code is apparently 'speed sensor' or something. I may still go to Vanmatic just to see what they have to say (and because my mother in law is visiting at the time so I'll not mind getting out for a few hours....) though I'm a bit reluctant to throw more money at it if it's not going to help - my mechanic gave me a bill for £300 as it is... I fear this may be the end of the road for me and the A8.... Anyone fancy a lovely 4.2 D2 in great shape apart from the gearbox?
Old 9th June 2015, 08:19 PM
what's the codes on the engine transmission line ?
as you can see there should be 3 !
if you don't have the sticker in the service book there is normally one on the spare wheel well !
and £300 ? do you live in mayfair ?
Old 10th June 2015, 11:14 AM
OK - the code from the service book is
ABZ DNW DTD.
The £300 included a cheap tyre and a hose which needed replacing. Other than that it was £37 for the filter, £24 for the gasket, £56 for oil plus VAT plus an hour's labour - so that seems reasonable?
I'm at a bit of a loss for what to do... Is it worth spending another £200 (or whatever) on taking it to the ZF specialist? What sort of money do you reckon the whole car is worth otherwise? It's in good shape, full service history with service book, cambelt done at 80k, now got 135k on the clock, MOT to end of year. Body is in good shape. There doesn't seem to be much point throwing more money at it if ultimately it needs a new gearbox for a couple of grand - which I'm not prepared to spend.
Old 10th June 2015, 11:33 AM
DTD was essentially the 'worst' gearbox for A8s. I'd just drive it until it dies, as pretty much your only other option is a replacement box.
Old 10th June 2015, 12:12 PM
well the value of the car depends on 3 things ...condition, condition and condition
point is , it's probably heading for the breakers as is , so little value , but you can't complain at your loss for 18 months pleasurable motoring at the price you paid
but what would you have to lay out to replace it ? and what sort of guarantee would that have ? at least if you spent money on this you would know what you had and the value when you came to sell it would be higher than it is right now !
maybe a new unit from ZF/ audi would be too expensive , but there are gearbox specialists about who would fit you a rebuild with a 2 year guarabtee for a considerably lower price
in the meantime keep your eye open for a used unit with the correct code , people on this forum are good at spotting such things and will tell you if they do !
Old 10th June 2015, 12:20 PM
Yeah - I guess. As much as I love it, it is quite impractical for me as I travel a lot with bicycles on board and an estate would really make a lot more sense. I have and old Passat estate which is battered but bulletproof - currently SORN but doesn't need much to get it back on the road. The sensible thing may just to see what I can get for the A8 and get the Passat back on the road for the mean time. Then when I'm a little more flush with funds an A6 estate would be lovely...
I may just post it up in the classifieds here and see if there are any takers. What sort of money would you get at a breakers? I gather all the aluminium makes the scrap value pretty high? Seems a real shame for such a car to go to it's grave though
Old 10th June 2015, 12:38 PM
well , nothing to stop you SORNing it for the moment and see what turns up ; the age of miracles may not be past !
but as a final throw of the dice , why not contact your mechanic , explain that after his labours the car is now scrap , and ask him to double check that the fluid level is correct , stranger things have happened if the to and fro on the box hasn't had the desired effect during the fill
wouldn't take him 10 minutes and after £300 he can afford it !
