Old 16th June 2015, 03:41 PM
mannyo mannyo is offline
Originally Posted by Witchfinder View Post
Interesting. Do you need to do something special when you change the battery? I had mine changed a few weeks ago, but I didn't know there was more to it than the changeover.
You need to code the battery module so it relearns the characteristics of the new battery, for example discharge rate. Currently your 8 may start switching things off needlessly because it thinks the battery is going to die faster than the new reality.
http://wiki.ross-tech.com/wiki/index...ry_Replacement
If the battery has the same AH and CCA then you usually just change the serial number slightly to fool it thinking it has a new battery.
Manny
Past
Old 17th June 2015, 09:40 AM
Witchfinder's Avatar
Witchfinder Witchfinder is offline
Another reason to think about getting VCDS then. Maybe later in the year of I'm a bit more flush.
Rob
2013 Audi A7 BiTDi, with Tech Pack High.
2007 Audi S8, with Rear Seat Entertainment, Quad Zone Climate, DAB/DVB and electric blinds. ** sold **
Old 17th June 2015, 08:19 PM
Car is still fine no more recurrence of the battery issue, but the annoying clicky flap motor is back again. Last time I fixed it for several months, but that same fix has not worked this time.
At some point I need to bite the bullet and replace that stuck flap motor in the engine bay, then I should be able to successfully complete the basic settings with all the motors and have them learn their new values.
Manny
Past
Old 19th June 2015, 05:22 PM
Did it again today, but no VCDS this time. I have a theory the issue revolves around the boot. Yesterday I was in and out of the boot several times in the evening, so I've opened and closed it this evening. Battery is currently sitting at 70% so I'll see later if its dropped down.
Manny
Past
Old 23rd June 2015, 12:11 PM
I am now reasonably sure its the boot causing the problem, not sure though if its because the light is not going out or because the latching mechanism is perhaps having issues. I did notice the other day that even though the boot was closed and could not be opened, I pushed down and there was a click from a latch or something. One thing is certain, it is sufficient in current draw to reduce the battery to low levels over just a few hours.
Manny
Past
Old 23rd June 2015, 12:17 PM
Sounds like you might be on to a winner, try getting inside and have someone shut you in, I've been in there before, even closed its quite roomy ��
Old 23rd June 2015, 12:50 PM
Turbo Tony's Avatar
Sounds like you might be on to a winner, try getting inside and have someone shut you in, I've been in there before either closed its quite roomy 😀
Lol. Del, are you suggesting this for fun, or as part of an actual solution to the problem?
Storytellers Villa Orlando
2008 Audi S8
