Old 18th June 2015, 10:24 PM
Zip's Avatar
Zip Zip is offline
Post
Originally Posted by Professor Peach View Post
Sorry to take your thread off topic again Zip, but it appears I'm not quite as stupid as we all thought (maybe). Mine doesn't tilt. I've tried every conceivable variation of twisting, turning, pushing & pulling on that control, but it only moves one way and that is a slide. Perhaps one day I will read this 'hand-book' you speak of. Just thought I'd share. Now back to topic.......
Yours must be broke.....
Z
Old 19th June 2015, 06:37 AM
Originally Posted by Zip View Post
My glass roof has hard 'velour' trim around the inside edge of the roof, and a sort of bellows section either side that expands up as the roof tilts up. I presume the screw heads for removing the panel are under there but I don't know how to remove it without breaking it.
Anyone know how? Ian?
Ta,
Z
Mine's a 2002 S8 too, so I assume it's the same fitting.
To remove it, first from inside the car retract the roof panel cover and, at the front of it, you can just see 2 clips. Push these apart with your finger to release them and then push the roof panel fully back.
On either side of the sunroof (use a torch) you can see the heads of 3 torx bolts. These are the ones that keep the sunroof in place and allow height adjustment.
It's hard to find a comfortable position and you need to be careful not to drop the bolts, but apart from that - simples!
Old 19th June 2015, 08:40 AM
Here's a bunch of ElsaWIN print outs for the various sunroof options - glass panel is as you'd expect subtly different
A
