Old 16th February 2010, 09:37 PM
staffdog
Guest
Posts: n/a
Default LED Bulb upgrade advice needed
Hi All,
just fitted 50w hid's to dip beams & 35w hid's to front fogs on my 4.2qs,Outstanding results lights much improved.
Just curious as to what sidelight bulbs others are using std 501's now look very yellow,maybe LED but unsure if led's will set fault on dis panel.
Anyone tried led's in rear lamps
Regards Adrian
Old 16th February 2010, 10:26 PM
Oli18's Avatar
Oli18 Oli18 is offline
Originally Posted by staffdog View Post
Hi All,
Pictures, pictures, pictures!!
For my 501s, i have used quad LED jobbies but they only direct light straight ahead.
As you can see, they look a little more blue than i had hoped (even though it says 'bright white' on the packaging) and don't illuminate the entire light cluster hence looking to change.
Today, I received a set of these multi-directional jobbies which i'm hoping look a bit better...I have not fit them yet.
Oli
Audi A8/S8 D2 Flickr Group
Old 16th February 2010, 11:43 PM
Look forward to a pic of your new ones Oli, I had the same problem as you. Too blue so I took them out!
Old 18th February 2010, 09:42 AM
Mr K Mr K is offline
Im interested to see the results too. Im also tempted to play with the interior bulbs, to get a whiter interior lighting. But theres always a risk of making it feel a bit tacky in there.
Old 18th February 2010, 06:43 PM
Oli18's Avatar
Conclusion:
Whiter than before, brighter than before and matches the OEM xenons better. You can - if you are really picky - still sometimes see a lightest blue tint but it's nowhere near what it was before.
Still, worth the £4 IMO.
Before and after
Low beam + new sidelights
Old 18th February 2010, 07:56 PM
I'll order them now. Linky please Oli?
Old 18th February 2010, 09:16 PM
Oli18's Avatar
It's from ebay.de but the items are shipped to anywhere in the EU from Hong Kong.
Oli
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
Old 19th February 2010, 01:21 AM
Thanks Oli, just ordered them.
Old 19th February 2010, 04:47 AM
darrenjoe90's Avatar
amar are you sure they will fit your lights ?
i got some of them and they did not fit my lights. mine were the ones that you push in and twist. that is the type of led side lights that i have.
Audi S8 Phantom Black
Old 19th February 2010, 01:05 PM
I think mine just push in but can't remember exactly. But my car has the factory Xenons just like Oli's, non Xenon Pluses like yours. I should have brought yours off you instead! How long does shipping take Oli?
