Hello everyone.
My D2 3.7 gearbox code FBB developed an interesting problem. Symptoms: After about 30min-45min minutes of driving it changes shifting strategy from fuel 'economy mode' into 'aggressive' kind of 'sports' mode. It basically downshifts abruptly and never upshifts back again. Releasing gas pedal completely doesn't help. Example: If I drive on highway on 5th gear @ 70mph @1500rpm all of a sudden the gearbox shifts to 3rd gear and just continues to drive on 3rd gear @70mph @3500 rpm. Releasing gas completely doesn't help to upshift back again. The only way to go to higher gear is to press gas to rev the engine till 4000-4500 rpm and then it will upshift, but only to 4th gear. This behaviour is similar to the sport mode, but of course I don't select the sport mode. I can override this by putting gearbox into tiptronic mode and manually selecting the 5th gear and continue my journey. But as soon as I disengage the tiptronic mode the behaviour gets back to the downshifted 'aggressive' mode. The behaviour will terminate as unexpectedly as it came. Sometimes it will last for about 30 minutes of driving and then disappears without a trace. Sometimes it will last for only several seconds -- you drive as per normal, then suddenly it shifts couple of gears down, engine revs, then in 3 seconds it is all gone, back to normal gear -- driver didn't do anything! :^) Analysis: I connected VCDS and started to look at gearbox oil temperature sensor reading (that's measuring group 7, field 1). That sensor is called G93 and it is part of the electric harness that feeds valves. It sits in the sump. When I come to cold car in the morning the sensor shows 28C when the ambient temperature sensor on the dash shows 14C. Weird. So I start driving. The temperature slowly raises to 78C-80C and stays there. After about 30 minutes of driving, out of the blue the sensor jumps from 80C to 155C within about 2 seconds and then stays at 155C. The same moment the crazy mode engages -- the gearbox downshifts and never upshifts back again. Perhaps we should call this mode a 'cooling off' mode? :^) Interestingly, there is no error logged in the gearbox ECU. Clearly, sensor can't change temperature from 80C to 155C within two seconds. Implausible sensor value should be detected by ECU software and logged as error, but it doesn't happen on my car. So the G93 oil temperature sensor and the corresponding harness is going to be changed ASAP. That is sump out job. My ask from you: Could some of you with D2s cars and VCDS cable measure for me the G93 gearbox oil temperature sensor reading (measuring group 7, field 1) when you sit into cold car in the morning, plus right after you finished 45+ min driving? I'd like the info in the following format: 1. Cold car before driving: G93 reading: xxC Ambient temperature on dash: yyC 2. Hot car after 45+ minutes of driving: G93 reading: xxC Engine displacement: 3.7 or 4.2 In terms of hot temperature reading I'm specifically interested in D2 cars with 3.7 engine. These engines come with gearboxes with separate oil coolers, which are not present on cars with 4.2 engines and S8, so they *can* run at lower temperatures. If your car is not 3.7, but you are willing to publish your readings here please specify your engine displacement. The most important reading for me is the cold reading, so if you can publish at least that one together with your dash ambient temperature reading I'll be equally grateful. Many thanks.
I'd rather drive on left Last edited by notorious; 16th August 2015 at 08:05 PM. |
Yes, with a bit of help from David (who has the VCDS just now) I could do the cold temp this weekend and the 45 minute drive temp on Monday if that's any help
..and as I havent got a car at the moment (still in garage, having belt/seal/exhaust done), I will return VCDS to the Laird.
About G93 sensor from here: http://vwts.ru/pps/pps_951903_01v_01...ssions_eng.pdf
TCC = Torque Converter Clutch
I'd rather drive on left |
I only have an older VAGcom 3.x presently, so hope this helps.
I was on my way out to the car to check/clear codes when I saw your post, so I grabbed a screenshot: (cold engine/box) The temperature reading on the dash was 14 degrees C. Sounds to me like you have a connection issue, perhaps one that is common to both the sensor and the selector.
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 31st July 2015 at 12:39 PM. |
Cheers Mark.
16C is very close to 14C. You're in good shape!
I'd rather drive on left Last edited by notorious; 31st July 2015 at 01:15 PM. |
I can check my 3.7 tomorrow and let you know sergey but you have a later gearbox than mine from memory as mine doesn't have sports mode
Confidence is the feeling you have before you know better . . . . ![]() Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble ![]() Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs Last edited by Architex_mA8tey; 31st July 2015 at 02:57 PM. |
OK, done.
At cold, the oil was 17C with an outside temperature of 14.5C. We did a total of about 22 miles on a mix of dual carriageway, B roads and around town. Outside temp ranged from 13.5 to 14.5 and the oil temp from about 74C to a max of 84C when I stopped after the run. Hope that is of some help Sergey.
Thanks Jim.
On fully warmed up car I also have around 80C (this is when the sensor behaves). I made more measurements today during driving and sometimes temperature starts to jump absolutely abnormally. I had no chance to make a screenshot with a graph, but it looks quite random. Then returns back to steady state at around 80C. When it jumps to 155C the gearbox shifting strategy changes. Need to change sensor.
After the German meet went to ZF Darmstadt and changed the oil temperature sensor with harness.
As part of the exercise they did complete gearbox service which included removing hydraulic switching unit and cleaning it. They also changed one piston (part number 1068 227 039), but it was not related to oil temperature sensor problem. Pictures!
