Old 9th August 2015, 08:03 AM
kfsn1 kfsn1 is offline
Default Squealing brakes
Brakes have got very squeaky the last few days but got no indication of low brake pads. They were recently checked and found to have plenty of pad left. Suspect the noise is coming from NSF wheel. Im confident its the brakes as it only happens when I apply the brakes, plus you can hear the squealing gets quieter and louder as the wheel rotates.
I'm thinking something has got trapped between the pad and disc. Has anyone got the way to remove and replace the back pad so?
Thank you.
Old 9th August 2015, 09:31 AM
Turbo Tony's Avatar
You could try spraying the area down with an iron dissolver like Iron-X or Bilt & Hamber Korrosol. That will dissolve any small iron particles (brake pad dust) that might be caught in the calliper.
It'll be difficult to get it into the calliper, but it's worth a try.
Otherwise, remove the pads and butter the backs of them with copper grease.
Storytellers Villa Orlando
2008 Audi S8
Old 9th August 2015, 09:46 AM
https://www.dropbox.com/s/hhulc5q5jp...ystem.pdf?dl=0
Old 10th August 2015, 06:00 AM
Thanks Turbo Tony and Snapdragon. I'm going to take a crack at the brakes tomorrow or Wednesday. I'm also debating whether to just get a full set of new pads for the front..... Will update on the outcome. Cheers gents.
