Hi,
Can someone shed a light on these error codes? I suspect a turbocharger but not too sure, obviously flashing glow plug light and check engine ON. Tuesday,07,July,2015,19:39:14:33490 VCDS Version: Release 12.12.3 Address 11: Engine II Labels: Redir Fail! Control Module Part Number: 4E1 910 409 A HW: 4E1 907 409 Component and/or Version: 4.2L V8TDI G000AGSª0070 Software Coding: 0011773 Work Shop Code: WSC 00752 210 91076 VCID: 224D9CD3FD4D230EAD9-8077 2 Faults Found: 005462 - Charge Pressure Control P1556 - 011 - Negative Deviation - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 0 Fault Frequency: 6 Reset counter: 255 Mileage: 171937 km Time Indication: 0 Date: 2015.07.05 Time: 11:33:59 Freeze Frame: RPM: 2037 /min Torque: 491.4 Nm 004455 - Mass Air Flow Sensor 2 (G246) P1167 - 001 - Implausible Signal Freeze Frame: Fault Status: 01110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 171948 km Time Indication: 0 Date: 2015.07.05 Time: 11:50:04 Freeze Frame: RPM: 1260 /min Torque: 3.9 Nm (no units): 76.0 (no units): 100.0 (no units): 16.0 __________________________________________________ ________________ Tuesday,07,July,2015,20:15:30:33490 VCDS Version: Release 12.12.3 Address 11: Engine II Labels: Redir Fail! Control Module Part Number: 4E1 910 409 A HW: 4E1 907 409 Component and/or Version: 4.2L V8TDI G000AGSª0070 Software Coding: 0011773 Work Shop Code: WSC 00752 210 91076 VCID: 224D9CD3FD4D230EAD9-8077 2 Faults Found: 005462 - Charge Pressure Control P1556 - 011 - Negative Deviation - Intermittent - MIL ON Freeze Frame: Fault Status: 10101011 Fault Priority: 0 Fault Frequency: 3 Reset counter: 255 Mileage: 171969 km Time Indication: 0 Date: 2015.07.07 Time: 19:55:46 Freeze Frame: RPM: 1848 /min Torque: 471.9 Nm 004455 - Mass Air Flow Sensor 2 (G246) P1167 - 001 - Implausible Signal Freeze Frame: Fault Status: 01110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 171974 km Time Indication: 0 Date: 2015.07.07 Time: 20:03:34 Freeze Frame: RPM: 1428 /min Torque: 3.9 Nm (no units): 88.0 (no units): 116.0 (no units): 44.0 Tuesday,07,July,2015,19:38:18:33490 VCDS Version: Release 12.12.3 Address 01: Engine Labels: Redir Fail! Control Module Part Number: 4E1 910 409 A HW: 4E1 907 409 Component and/or Version: 4.2L V8TDI G000AGMª0070 Software Coding: 0011773 Work Shop Code: WSC 00752 210 91076 VCID: 224D9CD3FD4D230EAD9-8077 4 Faults Found: 000257 - Mass Air Flow Sensor (G70) P0101 - 002 - Implausible Signal Freeze Frame: Fault Status: 01110010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 171965 km Time Indication: 0 Date: 2015.07.06 Time: 21:42:02 Freeze Frame: RPM: 1050 /min Torque: 3.9 Nm (no units): 64.0 (no units): 120.0 (no units): 8.0 004104 - Mass Air Flow Sensor 1/2 P1008 - 000 - Implausible Signal Freeze Frame: Fault Status: 01110000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 171967 km Time Indication: 0 Date: 2015.07.06 Time: 21:44:54 Freeze Frame: RPM: 1260 /min Torque: 3.9 Nm (no units): 1.74 (no units): 100.0 (no units): 100.0 005462 - Charge Pressure Control P1556 - 011 - Negative Deviation - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 171968 km Time Indication: 0 Date: 2015.07.06 Time: 22:00:46 Freeze Frame: RPM: 1701 /min Torque: 292.5 Nm and some logs: http://vaglog.pl/log_224272.html http://vaglog.pl/log_224273.html http://vaglog.pl/log_224274.html Any help much appreciated. Thanks
Can you hear any hissing when under boost e.g inter cooler or associated pipe work leaking boost
Look at both air flow meter signals and compare on the road to see the difference ,if one is way off to the other . Negative deviation is a fancy term for boost being low for given load factors . Try to look at both turbo actuators get someone to turn ignition on and off and see if actuators do a 'full sweep' with a smooth action ,or see in the vcds actuations menu to see if you can drive them . Air mass meters rarely give codes because the signals have to go through such varying load factors ,the air mass signals are not interrogated by ecm control , it's the consequential effects of it that the ecm picks up on such as wastegate control If the turbo wastegate controllers are electronic they should flag codes because they have feedback to ecm e.g if the variable vanes where sticking The 3l v6 jags flag 'p134b turbo control fault 'when it sees sticking vanes or high load feedback on the motor controller . A few things there to go at |
Thanks for the reply.
Will give a to-do list to my friend ![]()
Your work in It ......oh in that case switch it off an on again ....be reet
Ok, light blue smoke from the left exhaust pipe doesn`t sound good, does it sound like turbo to be replaced? How much would it cost to replace the turbo (labour cost) ?
![]() Last edited by genmaxiu; 12th August 2015 at 04:18 PM. |
Could be turbo failed , never done one but they look arkward to do
OK, faulty turbo on the left side. Both are now sent out for regeneration. Any advise on what to check/replace while front end is in bits?
EDIT: Both turbo`s regenerated (£500 for both) and fitted back (£600) , car drives like a dream, there must have been something not right since I`ve bought it, is now much much more responsive than before.
![]() Last edited by genmaxiu; 25th September 2015 at 07:18 AM. Reason: New info added |
