Old 13th August 2015, 10:30 PM
It does have the mounting holes, at least it did on mine, they are not the easiest to see but are there
Old 13th August 2015, 10:31 PM
Hmm maybe they started fitting them as standard from a certain date then, I'm not sure all D3's would have them
Old 13th August 2015, 10:33 PM
The Acc was available from 2003 on was it not, just had a quick look in ETKA its the same part number all the way from 2003-2007
Old 13th August 2015, 10:58 PM
mcs's Avatar
mcs mcs is offline
Yes,
The pre-facelift cars retrofit is even easier than the later ones. You only need the small lower grill with the radar cover.
In most countries ACC was available from day 1 of production but it was a hefty extra-cost option.
I am keen to see what happens with the wiring Delboy, that is the only thing I am worried about with this retrofit. Where do the CAN wires attach and how.
Mike
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 15th August 2015, 11:33 AM
Hi Mike,
Hope you have had time to study Del's excellent write up regarding the ACC retrofit. The CAN connections and wiring for the ACC is relatively simple because it is its own CAN, known as CAN-E or Extended CAN, with only two network nodes - the radar and the gateway.
It has its own network because the radar broadcasts a lot of data at the highest importance level.
If the ACC nodes were on another CAN network this would result in lower priority data being delayed as only one CAN payload can be on the BUS (which would nearly always be the ACC data) Therefore a dedicated CAN for ACC is the best solution.
To simplify the CAN-E network even further, from ISO11898-2, the resistors are terminated in the CAN Controllers within each node.
So in reality this means only a simple twisted pair is needed between the radar and the gateway.
Matt
Old 16th August 2015, 09:48 PM
Turbo Tony's Avatar
Thanks very much for taking the trouble of writing this thread Del.
A couple of silly questions, please:
1) Did the S8 instrument pack for ACC have the red LEDs around the speedo?
2) What's the lowest speed the ACC will operate down to?
3) How has the system been working for you?
Storytellers Villa Orlando
2008 Audi S8
Old 16th August 2015, 10:48 PM
Hi Tony the Acc cluster does have the led's, it works like the one in this video
The system becomes available at 20mph and can operate up to 120mph
It will stay engaged a bit below 20mph but not sure how far and for how long.
Its been working fine, since I last tweaked it but its not really a system for in the town, and makes for a better experience on open road.
