#31
DEL You Sir are a legend !
![]() Thank you very much for that... I will order it tomorrow. Il check my readings today as my simptoms are very similar to manny.. If only you could help me with lane assist ... Auto glass fit a new screen and now my lane assist has stopped working ... it says incorrect basic settings performed ![]() I must admit I miss it on jurneys especially with narkalepsy ![]() |
#32
I assume being a W12 to adjust mine it's a bumper off job ? :s
#33
To adjust the radar? No the cover plate gives access to the radar through the hole, horizontal adjustment screw is a **** to get too and you may need to make a tool to fit
Del ![]() |
#34
#35
After the retrofit most of the driving had been round town but yesterday I went to Norwich to meet with Matt for breakfast so had a 60 mile round trip, the ACC performed well apart from the slight bias that was noticeable during sweeping bends.
So I was surprised to get readings like these. I am reluctant to reset and think I will let it play out for a while yet and see what happens to it as we don't know know the criteria for setting the values. Is it over a long period or the last moments of a drive cycle etc
Del ![]() Last edited by Delboy; 23rd August 2015 at 09:48 AM. |
#36
I've no idea... I can't actually remember when I did the retro fit on my 4.2 how i self calibrated it.
I think I actually parked behind a car in a car park and used that to zero the basic settings and it was absolutely spot on... But I'm guessing I must need to lower the radar on the W12 because it picks up larger vehicles but not cars.. And the 4.2 picked up motorcycles and all sorts |
#37
This morning I added 1/2 a turn anticlockwise to the horizontal adjustment screw, and reset the basic settings. Having driven 150 miles since I now have different readings. I'll not post another screen shot, but the channel values recorded as follows:
Channel 2 first block -0.083 degrees Channel 11 first block: -2.016 degrees Observations when using ACC, it now at least seems to see cars in front but needs more adjustment I think. From this I think we can deduce that channel 11 is horizontal alignment and channel 2 is vertical, and to get from negative figures to towards zero on the horizontal seems to need anticlockwise on the allen key.
#39
Interesting as that would mean mine was pretty close at the start and should have worked, but it quiet clearly is miles out.
I guess adjusting the horizontal is correcting the steering offset in block 11 position 1. I know my wheel alignment is spot on, i've had it checked twice in the last 12 months on a hunter 4WA rig and its never required adjusting.
#40
Yeah it will be interesting to see how it changes, your middle lane check is a good way to do it.
Del ![]() |
