Old 8th September 2015, 02:01 PM
It is perfectly possible for the battery to just die - I had this happen once on a 7 series BMW and it cold started normally, I drove about 40 miles to a meeting then it died whilst I was in the meeting. I'd be tempted to check all your earths first to make sure they are sound battery to car and starter earth and live connections. failing that I'd be tempted to take the battery off and take it to a Halfrauds or battery shop and get it properly tested and then replace if its rubbish and recode the new one on to the car.
Old 8th September 2015, 02:20 PM
A8L A8L is offline
That makes sense, I'm off to Halfauds! Thanks
Old 8th September 2015, 02:21 PM
A8L A8L is offline
anything I should note when removing the battery or is it just unbolt and remove?
Old 8th September 2015, 03:09 PM
If your car is in the garage I would leave the windows down and doors/boot unlocked before taking the battery off just to make sure
Just remove the battery in normal way but new one needs coding to the car on fitting
Old 8th September 2015, 03:21 PM
A8L A8L is offline
OK battery out - boot left open, halfrauds here I come
Old 8th September 2015, 04:35 PM
A8L A8L is offline
£160 and a new battery fitted but the same issue is happening. I managed to run a scan after swapping the battery (attached) but I am in the same position where it wont let me do another scan, getting the same error.
File Type: txt new batteryLog-OV04YDJ-WAUZZZ4E64N015552-133300km-82828mi.txt (22.9 KB, 323 views)
Old 8th September 2015, 04:49 PM
It's not the battery.
Do you get lights on the dash when ignition is turned on?
I'd be looking at all the fuses including the BIG ones.
Old 8th September 2015, 07:47 PM
A8L A8L is offline
Hi Dezzy
Yep, I think that's fair to say! I suppose on the upside, my old battery was tested and the advisory was to replace it - the voltage was lower that low!
I don't get any dash lights when the ignition is turned on which is how it was pre new battery. As soon as the new battery was in, I noticed straight away that the dash lights were still not coming on - I get the mileage lit up but no ignition lights.
I'm not sure where to start with the fuses and where do I get new ones Big ones
Any pointers on the fuses, which ones to replace, test etc - can they be tested or is the test to replace it??
Old 8th September 2015, 08:55 PM
Dave McB Dave McB is offline
sounds like it could be a bad earth
As for a jump starter pack, you should get one of those lil pocket sized ones - I have one and its fantastic
(google search 'angry jester' - theres a lot of variations on the market)
If youre near to me (Glasgow) I can borrow the battery tester from work and test your old battery - alternatively I can take your old one on for a charge
Old 8th September 2015, 09:56 PM
Sorry to hear the battery didn't solve it, but it sounds like it did still have issues. I did say check the earths on the car and on the starter etc it would certainly be wise to see if you can scan the car and pick up on any issues before doing too much more.
