Old 9th September 2015, 11:33 AM
Burnzybubbles's Avatar
Default What's your DAB soft code?
Could someone please put up the soft coding for there DAB preferably a diesel if they can but petrol is probably fine too, I reckon this is the problem with my incorrectly coded message, my DVB was incorrectly coded too but thanks to the other thread iv changed that, so if someone could post up the code that would be great
Thanks
Old 9th September 2015, 12:13 PM
Once I'm at home later I'll take a look for you
Matt
Old 9th September 2015, 12:20 PM
That'd be brilliant if you could matty, thanks
Old 9th September 2015, 05:38 PM
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7100089
Coding: 0000001
Shop #: WSC 02152 785 00200
VCID: 2447F597E7C9F3012A7-8071
Matt
Old 9th September 2015, 06:27 PM
Address 0F: Digital Radio Labels: NONE
Revision: 00000001 Serial number: KE1229T8000027
Coding: 0000001
Old 9th September 2015, 07:51 PM
Thanks guys, unfortunately mine is the same so it's not that :rofl:
I'll have a play tomorrow, iv got vag commander and I have some component protection active, as ours is only the mk1 component protection I'm hoping commander will virginise the modules for me so I can DIY it and hopefully get rid of the protection on the stereo and passenger memory module that I replaced
Old 9th September 2015, 09:11 PM
I am not aware of anything that can remove component protection on the D3 apart from a connection to dealer HQ from either an Audi dealer or authorised independent. It maybe MK1, but the coding has never been cracked.
Old 9th September 2015, 10:27 PM
I'm sure I read somewhere that gen 1 component protection doesn't use the online database and is a lot simpler compared to gen 2 CP, there is other tools on the market that will remove CP not just main dealers.
http://youtu.be/JYmdqKfn_Ns
Old 9th September 2015, 11:08 PM
Interesting video Burnzy. Also, does VAG Commander work with any OBD II cable (i.e VCDS cable)??
Matt
Old 10th September 2015, 05:27 AM
AVDI looks interesting, but at €10K+ for all the modules plus annual maintenance on top, I'd stick with VCDS for the basics and the dealer for CP issues.
http://shop.abrites.com/index.php?ro...tegory&path=57
